Super Beverage Cooler
To create an instant beverage cooler from an old water cooler.
Replace the compressor with a bigger one, replace the condensor with a bigger one, chop a couple feet out of the middle, charge it with propane & fill the tank with brine!
Step 1Out with the old
Out with the old
After the sheet metal & plastic sides are removed, this it what is left.
25 comments
Jul 16, 2009. 3:39 PMheaddead says:
Got a link to the chart?
Feb 16, 2009. 6:14 PMhg341 says:
nice i would like to make 1
Dec 6, 2006. 3:50 AMPocket Universe says:
I'm not sure that I'd dare to keep that baby around the house but it's a damn cool project (no pun intended), that's for sure.
Aug 14, 2008. 10:17 AMbikerbob2005 says:
1.2 oz of propane scares you?my hobby torch uses 12 or 16 oz cans .my pocket torch for radio shack holds about an oz of butane and its clear plastic :O
Aug 17, 2008. 3:59 AMPocket Universe says:
What can I say, you're a brave man :-)
Jun 18, 2008. 2:12 PMEsmagamus says:
I loved your instructable and I'm considering making a mod like this, but there is one piece of information I haven't stumbled upon yet: How do you calculate the necessary amount of propane to charge the circuit with? Do you just use a pressure regulator and leave the tank to fill the system to the pressure set in the regulator or do you make some kind of calculation based on the ideal gas law? Also, what kind of oil can be used with propane? Mineral?
Jul 9, 2008. 3:51 PMEsmagamus says:
Well, there is no EPA or US government to worry about here (not in the US). Still, I was wondering how you managed to calculate the amount of refrigerant needed. I've been hunting through the US Army refrigeration course and I can't find that in any part of it.
Jul 12, 2008. 1:22 PMEsmagamus says:
Thank you! It's just the pieces of information I was trying to find, the only issue is that the motor didn't have the data plate on it, so I'll have to try something else. Cool ideas!
Jun 10, 2008. 1:25 PMEsmagamus says:
Does it have an expansion bulb or waterver you call that little copper bulb?
Oct 18, 2006. 2:21 AMMyself says:
Wow, I stand corrected! My assertion of propane's greenhouseness was guilt-by-association with methane, which appears to have been a laughably invalid assumption. My apologies. I'm still curious as to how necessary the new compressor and condenser were. Isn't the target temperature for the can of pop within the original water cooler's range? Or was it the need for speed, and a dramatically-colder bath temperature to quick-chill the can, that drove the upgrades? Given that you're getting below freezing now, will a can explode or deform if left in the bath too long? How loud is the unit when the fans are running? I'd imagine that their speed is easily adjustable, being DC-driven. The near-silence of water coolers has always been an attractive feature. Is the new compressor similarly demure?
Feb 8, 2008. 4:47 PMScottSEA says:
Gotta say, I love it when someone is big enough admit it, and then apologize when they make a mistake. Almost as cool as this instructable. Excellent.
Oct 16, 2006. 9:58 PMMyself says:
So what you're saying is "build a beverage cooler that looks like a water cooler, but in fact shares almost none of the original components".
It would've been 10x more interesting if you'd found a way to do it *without* junking most of the parts that make a water cooler a water cooler. Say, by adding insulation around the top pot so it'd reach even colder temperatures on the stock cooling unit. Or something.
Anyway, propane's a greenhouse gas so I hope you recover it properly when you reuse these parts for another project. As I'm sure you did for the refrigerant that was already in it, right?
Oct 20, 2007. 4:14 PMMr. Smart Kid says:
also propane is not in the atmosphere, IT"S MAN-MADE
Dec 8, 2006. 12:08 AMassplosionz says:
you are a fool propane is not a greenhouse gas and dont criticise his work if you can do better i would love to see
Oct 20, 2006. 3:56 PMlemonie says:
Cooling systems used to be filled with nice safe non-flammable chlorofluorocarbons, but since they're almost globally banned we're back to the likes of propane & possibly ammonia(?). As commented, in a closed system there's no problem. Of course before CFCs fridges used to be filled with ammonia etc...
Oct 14, 2006. 8:48 PMkrusty says:
Is there any risk of fire/explosion from using propane as the refrigerant ?
Oct 16, 2006. 5:27 AMThe Moog says:
I wouldn’t recommend using propane, why do you think manufacturers don’t, they only use inert gas.
Oct 15, 2006. 12:26 AMtrebuchet03 says:
Only if it leaks - otherwise, not really ;)
Oct 14, 2006. 5:26 PMTheCheese9921 says:
needs spinners thats uber awsome
Oct 14, 2006. 2:46 PMtrebuchet03 says:
the perspective makes the propane tank look HUGE!
Oct 14, 2006. 1:57 PMbleachworthy says:
gimme one!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:o4tuna
