Super Bright LED Flash Light With Reflector
1,838
20
Posted in TechnologyElectronics
Introduction: Super Bright LED Flash Light With Reflector
Here i am showing you how to make a super bright LED flash light with pyramid reflector.We use lesser components to make this.Its so compact and bright.We can simple change battery and its less expensive
Step 1: Components Need
1.9v battery
2.one old 9v battery -used to get the connector
3.100/220 ohm resistor
4. white leds-6
5.card board pieces
6.aluminum foil
7.push button switch
8.glue,soldering iron,hot glue
Step 2: Dimensions of the Cardboard Pieces
These are the dimensions of the cardboard piece cuttings
Step 3: Circuit
Its so simple circuit.Here we used only 6 leds,one 220 or 100 ohm resistor,and a 9v battery.
Here we make a series connected three pairs of leds and these 3 series connected leds are connected parallel
and it connected to a 9 v battery through a 220 ohm resistor.
Step 4: Steps 1
- First we cover the cardboard pieces with aluminum foil paper,to make the reflector
- On the 2.5*2.5 square cardboard we connected the 6 leds
- And connect it as per the circuit and solder it
Step 5: Step 2
- Take out the connector from the old 9v battery
- Using adhesive tape stick the each pieces of reflector and make a pyramid shape
- Stick the reflector permanently using hot glue
Step 6: Step 3
- Attach the LED section with the reflector using hot glue
- Attach a push button on the side using hot glue
- Connect a 220 ohm resistor from led +ve to one pint of push button switch
- The next point of push button connect to battery +ve terminal
- connect the -ve terminal to battery -ve point
- Cover the soldering parts using an insulating tape
Step 7: Super Bright Flash Light
Here we finished our project.Please try this in your home.Feel free to ask any one of your doubts.Please like and share my videos and subscribe my channel.Thank you very much
    • Spotless Contest
      Spotless Contest
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
