Step 4Before You Cut - Please Read
L.E.D Strip Lights: For outdoor use the weather proof works best. The strip is lined with a heavy plastic coating that protects the circuit from moisture, water and dirt. They run on both DC (plug-in power from a wall) and AC (battery power).
The L.E.D’s need 12 volts to run, in this case a 9 volt battery is used and able to power the lights. It’s important to note that power should not exceed 12 volts, if so, you run the risk in blowing out all the L.E.Ds. The strip has a continuous circuit of positive and negative running through them. Every two inches you can cut the strip using the cut area and reconnect them.
Add Comment
