Super Capacitor Battery for Mouse
14,336
199
29
Posted
Introduction: Super Capacitor Battery for Mouse
Let's make unlimited times and quickly chargeable Supercapacitor battery for mouse.
What we need:
Step 1: Schematic. Difference Between Capacitor and Battery
As You can see in diagram ordinary battery don't have so big voltage drop during discharging as capacitor have. Because of that 5.5v ultracapacitor will work until it drops from 5.5v to about 1.5v so voltage limiter will supply to mouse about 1.1 volt.
Step 2: Build & Charge & Go...
Step 3: After Word
At the end it turn out that it of course is not keeping charge as long as ordinary battery. Also Capacitor have quite quick self discharge.
May be in near future I will add some resistor for limiting current going to mouse. Probably adding diodes between charger<->capacitor and capacitor<->voltage regulator would be nice idea as well.
P.S. Mouse warranty is voided.
  • Made it with 10F cap...-Suraj Grewal
    Suraj Grewal made it!
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
27 Comments
Actually it is not the capacitors fault that it won't last as long as the battery.
I'm assuming the mouse draws on avarage less than 1mA active, and down to several uA when not used. Open the datasheet of the 1117 and read the electrical specification. You should notice the entries "Minium load current" and "Quiescent current", that is the current permanetly drawn. No wondere the mouse doesen't last long, it increses the consumption by more than 5 times!
The obvious solution is replacing the 1117 by a better LDO with lower quiescent current. In that regard on of the best on the market is microchips MCP1710, it features a quiescent current of 20nA (!), thats 0.0004% (!). The dropout voltage is about 450mV, not bad at all. Also, when selecting filter capacitors make sure you pick ceramic ones (preferably X7R/ X5R type), other types can have a significan leaakage current of several uA. A smart choice would be to pick a 1.2V regulator to be able to use ub as much of the capacitors charge as possible.
To estimate the final runtime this calculator is super helpful. With the new regulator I get about 1 hour of runtime, which is enough considering the very short charge time.
Wow, never thought something like a mouse can last for 1 hour with the capacitor. But how long it take to charge the capacitor?
I'm glad you ask.
The charge time heavily depends on the capacitor type used, especially it's internal eqivilant series resistance. I've looked up a few examples and as an avarage value you have to expect around 30 ohms with the shown type. This leads to an "RC-constant" (yes, this is a real thing) of R*C = 30ohm * 1F = 30s. As a rule of thumb after about 5RC (2,5min) the capacitor will be fully charged. You should also take in consideration that the capacitor won't be drained completely and this are only rough calculations. I'm assuming you could get at least 30min runtime out of a 1min charge time, more than enough for a power point presentation.
what would be sweet is a magnetic mouse pad and some inductors in the mouse so the motion of the mouse would generate electricity and store in a supercapacitor. it would probably produce more than it needs. or worse case an induction mouse pad plugged into a usb port to keep it charged.
How about connecting two or three 1F caps in parallel. There is enough space, is it possible?
tried it...9F...lasts 30 minutes
9 Farad lasts 30 minutes? Wow, it doesn't seem like it is worth to make.
now i upgraded the 1117 with tda3663...now it lasts for a day
Charged it today morning...its evening and it still has power.
