loading
loading
Picture of Super Cheap Small Parts Storage
I love free stuff from junk. This is a project to give you lots of small parts storage for almost no cost but your effort. The result is a set of ten to hundreds of small part storage containers, perfect for nuts, bolts, buttons, and the like. You can buy storage systems but you may be put off by the price.
Step 1: Materials
Picture of Materials
Large number of cleaned cat food cans or other small free containers. Cardboard. Construction adhesive.
Step 2: Construction
Picture of Construction
Decide on your base size. Do this by laying out a set of containers and see how much area they take up. I used 12 inches by 18 inches. This is a size that gets a good number of containers on each level, but leaves each level a easy size to handle. Cut the cardboard. Plan the layout of the containers, perhaps even marking guide lines on the cardboard. I just eyeballed it. Put 4 dabs of construction adhesive on the bottom of the can and press in place. Construction adhesive is the stuff to use because it is a gooey stuff and fill in any gaps. It is also strong. Place the second can, there should be a dab of adhesive at the upper rim where the cans touch. This gives the whole construct a surprising strength, much more than gluing to the cardboard alone.
The units can be easily stacked to a surprising height. To aid in this you may want to add some guides to the bottom of each unit. What I did was to cut two disks of cardboard just a bit smaller than a can and glued these on the bottom of the unit. When stacked the disk goes in the can of the unit below and stops it from slipping sideways.
Step 3: Use
Picture of Use
Surely if you have gotten this far no directions are necessary.
D006DR2 years ago
Nice tip. Love it.
Jmae5 years ago
What about clear plastic lids so that you can hang it on a wall? I just can't find any lids that would fit... :(
spacenookie7 years ago
you could cut square or tubular stock and glue it to the substrate for compartments as well. When I first saw your picture I thought you were using the cardboard that comes with paper towel rolls.
I actually use this too. Very Effective. My dad owns a business called EEIAM(They work with computers). My family always save their tins but they dont work with ICs and parts that have to be in anti static bags. Good instructables!!
burzvingion7 years ago
hmm... interesting, but it seems a little limited. For one thing, you can't really tell what is where except on the top layer. This wouldn't be too much of a problem if you keep related items on the same layer (i.e. resistors of various values on one layer, electrolytics on another, etc), but for esoteric things it might be annoying. Secondly, getting one of the bottom layers out would be frustrating for me... I can just see everything spilling all over. Perhaps it would be nice to make a frame for them with slits up the sides for the "racks" to slide into (like an oven). Overall a good idea though, and a great way to re-purpose tuna/cat food cans.
russ_hensel (author)  burzvingion7 years ago
Perhaps a label on the end, bent down to make it more visible would help.
A related Instructable Ultimate Parts Storage, http://www.instructables.com/id/Ultimate-Parts-Storage/ might be better for your applications.
actually, I prefer the big plastic organizers with lots of little clear drawers. A quick google for "plastic drawer cabinet" led to this one on amazon.
