A fog chiller cools down fog from a fog machine so that it stays low to the ground. This one costs around $5-$10. I had everything I needed already, you probably do also.
Step 1: Materials
There is not much that you need for this project.
MATERIALS
1. Foam cooler
2. Dryer hose
3. fog machine
4. Ice
TOOLS
1. compass
2. knife
Step 2: Measure
You need to cut a hole in both sides of the cooler for the dryer hose, so:
set your compass to 6.5 cm and draw two circles, on opposite sides of the cooler (longways)
Step 3: Cut
Cut out the circles you just drew, the cooler should now look like this
Step 4: Feed
Feed the dryer hose through the two holes. leave one end longer that the other. one side should have about 4 in coming out, the other about 10. try bending the hose inside the cooler to get the most contact with ice.
Step 5: Ice
Fill the cooler with ice
Step 6: Attach
Attach The cooler to your fog machine by pushing the longer end of hose around the nozzle of the fog machine. just keep the two together and all of the fog will go into the hose.
Step 7: Fog!
turn on the fog machine and enjoy your fog not floating away!
Anyways, if it helps what I used was a Sunterra Mistmaker Fogger http://www.sunterrausa.com/decorative-accessories/product/300409 that I picked up at Menards. It seems they have something similar listed on their website now. http://www.menards.com/main/p-1657811-c-10121.htm (the LED setup is different).
The first time I tried combining the jack-o-lanter, the pond pump, and the mister I put it in the "catch pond". It wasn't bad but well... you can guess how much better it looked with the fog mister inside the pumpkin...
http://www.musiciansfriend.com/product/Lighting-400W-Fog-Machine?sku=801401
What I mean by "Their" dry ice, is that most of their cooled goods that have to travel by air, will be packed with dry ice. In fact, it could possibly be that they use it for a multitude of other packaging needs as well.
I have purchased pounds of dry ice this way. They have NO use for it after it has arrived, and a token sum is usually all they ask in return, if anything.
So I am thinking this: If you were to trade in your Styrofoam for a rubbermaid container, you could seal the holes around the flexible ducting, and then fill it with alcohol, isopropyl works.... anything with a LOW freezing point. You then put the dry ice into that, and you'll have a SUPER COLD source to cool your fog... you could BLAST TONS through here, and it would all get nicely cooled.
the theater i work in has a couple of homebuilt dry ice foggers that are pretty nice. all you need is a plastic drum, a wooden lid, broom handle, wire basket, and dryer hose. an immersion heater helps, too, but isn't absolutely necessary. maybe i should make an instructable for that....
But, thanks to Goodwill, I am cool like ballerboi because I have a fog machine. My wife still doesn't really understand this fact.
