Super Easy DIY a Solar USB Charger Backpack!
14,989
308
Published
Introduction: Super Easy DIY a Solar USB Charger Backpack!
About: Howdy, we are application engineers in Seeed. Sharing projects with maker community is awesome. Hope you like it XD Seeed is the IoT hardware enabler providing services that empower IoT developers to swiftl...
Let the sun lend you power when you need power and battery is dead~Praise the sun!
Here share my latest project, a Solar USB Charger Backpack~
Step 1: We Need
Hardware:
Structure:
  • 3D printed case
  • Wood fasteners
  • M3*8 screw * 16
  • M3 screw nut * 16
  • Backpack
Tool:
  • Screwdriver
  • Knife
Step 2: Build and Test the Hardware
The hardware include following parts:
Solar Panel,Lipo Rider,Lipo battery,and Micro USB Cable(maybe you need the cable to connect other device) Put the Lipo battery plug to lipo rider interface BAT, Put the Solar Panel plug to lipo rider interface SOLAR, Today is a good day, very sunny, so when I connect Lipo rider and solar panel, we can see the red led in lipo rider is on. It means that the solar panel is charging. Then make the toggle switch SW1 on and put the fun plug into lipo rider interface OUTPUT, the fun is working. So the hardware are good.
Step 3: Build the Shell for Lipo Rider and Lipo
Use the 3D printer to print the shell, here the 3D print file I provided is just for Lipo rider V1.3 and Lipo Battery 38*42*3.7mm. If you have other version of Lipo Rider, you need adjustment the size of shell.
Maybe we use different 3D printer, get the shell’s size will a little different too. so we can use such as rasp or sandpaper to adjust the size. then, make the Lipo under the Lipo Rider and put them to the shell, install the cap. now this is already a mobile power. connect the micro USB cable you can use it for charging. of course use sun’s power is this thing’s feature.
Step 4: Prepare the Material for Combination Solar Panel and Backpack
Use laser cutter cut the 3mm wooden planks, get the parts for fix Solar Panel and Lipo. here you also need Solar Panel, Lipo, backpack, bolts, nuts, knife and screwdriver.
Step 5: Mark in the Backpack
Put the Solar Panel to the place which you want fix in backpack, the put the wooden part to four corners of Solar Panel, then use pen mark the place, total of 16 marks.
Step 6: Installation the Solar Panel to Backpack
Use the knife to cut small cross in those marks, the hole’s size is just able to put the screw in. then put all of screw in the holes, note that the mounting screws from the inside. then start to install wood part, we have to first install the wood in hard place, then install the Solar plant, after that install the wood part in hard place.
Step 7: Connect the Solar Plant and Mobile Power
This step is easy, connect the solar plant and mobile power, then you can hide the mobile power in you backpack, when your backpack face to sun, it can get the power from sun and save it in mobile power, you can use it when you need.
Step 8: Done
Thanks for watching~
Renewable Energy Contest
First Prize in the
  • Planter Challenge
    Planter Challenge
  • Clocks Contest
    Clocks Contest
  • Oil Contest
    Oil Contest
3 Comments
and also add a battery?
the lipo rider charges too slow for a large battery. Charging with solar power alone, it would take several days to charge a 10000mah battery. But I do agree, a 550mah battery isn't even enough to charge a smartphone half way.
In fact, with a larger capacity lithium battery would be more practical, such as 10000 mAh lithium battery
