3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Super-Easy Fudge
Super-Easy Fudge
I found this recipe in a book, but I've seen it in some other places too. It's so easy and versatile that I don't think I'd ever try to make fudge any other way. 3-4 ingredients, just melt, mix, and pour. The best part: You don't need a candy thermometer!
I use a makeshift double boiler, but it isn't really necessary because you melt the chocolate with the condensed milk. I just like it to make sure nothing burns and because I usually make multiple types of fudge and then I can just change bowls.
With this recipe, you can make almost any kind of fudge (well, at least any flavor that they make "chips" of - chocolate, peanut butter, white chocolate, mint...). Just substitute in the same amount of other-chips for the chocolate chips. Note - the white chocolate didn't set as well as the others, but it was still good.
Step 1Ingredients
Ingredients
  1. 3 cups of chocolate chips (or any combo of chips)
    • 1 cup peanut butter chips with 2 cups chocolate chips is my favorite!
  2. One 14-ounce can of sweetened condensed milk
    • Make sure you don't get evaporated milk, they look very similar in the store
  3. 1/8 tsp salt
  4. 1 tsp vanilla extract
  5. 1 cup walnut pieces (optional)
  6. butter or pan spray for the pan if you don't use foil
Tools
  1. 8x8 square pan
    • I'm using a larger one because I made a double batch
  2. Measuring cups and spoons
  3. Foil for lining the pan (optional)
  4. Double boiler setup
    • You could also just use a saucepan as I already noted
    • If you have a double boiler, use it! I'm jealous ;)
    • I used to have the perfect bowls that would sit in my saucepans. These bowls don't.
    • I tried to use the larger saucepan with a strainer in it, then bowls (bowls are so that I can change between flavors without doing dishes!). The strainer started to melt a little (oops!) so I had to stop that.
    • I wound up with a pan inside a pan. This is your best bet if you don't have a double boiler.
12 comments
Jan 30, 2012. 9:58 AMclem79 says:
Can you use cupcake cups to pour it into instead of the foil in the pan? I was thinking that the ripples in the cupcake cups would make a nice design in the side and would be in personal sized pieces. I am new to making fudge and your recipe seems like one i can follow.
Dec 21, 2011. 1:55 PMzurichko says:
Just made some! Delicious! Thank you and Merry Christmas!
Dec 18, 2011. 2:18 PMCaralee76 says:
I just tried this and used the microwave to melt the choc chips/milk mix. I started with 3 minutes, but stopped it after 2 ½ and stirred and it all melted. I don't use the microwave much because I don't think it's healthy, but once a year for fudge is worth it! Thanks for the easy recipe!
Sep 26, 2011. 2:07 PMfeyo123 says:
i make this to cover some cupcakes!! and some left and i make bars. try the cupcakes its a really nice combo.
Mar 16, 2011. 6:51 AMAmon-100 says:
Great recipe try it as soon i a can get some condensed milk, I'm thinking back chocolate, and nuts
I would just like to say for any one melting the chocolate in a bowl on top of a pot of hot water for god sake make sure that the bowl doesn't fit the pot so well it makes a seal,
This happen to my mother quite a few years ago, steam built up under the bowl and a blast hit her in the face and burned her quite badly.
I don't mean to break out the doom and gloom but it can happen so very easily and no one should have to experience the pain of a steam burn ever.
Mar 1, 2011. 2:56 PMhjostrander says:
Will it work with regular milk instead of condensed milk??? i need some thing really easy to bake!!!
Mar 1, 2011. 4:28 PMhjostrander says:
oh ok... i just wanted to make my mom a random nice thing when she wasn't home, but, u know, maybe another time. :)
Dec 23, 2010. 12:01 PMmariomaster856 says:
i love the peanutbutter chocolate also cause there my fav mix
Dec 22, 2010. 7:21 AMbob48220 says:
ever try putting in ice cube tray to cool? plastic or flexible one would prob. b best. then no cutting. or different shaped molds like say for holidays. this recipe is usually on can of sweetened condensed milk or chip bag
Dec 22, 2010. 2:54 AMjoannafarthy says:
Looks super! Will try for sure!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
17
Author:jwystup(Professional Site)
I am a computer programmer. I like to cook and make awesome things.
