Super-Easy Fume Extractor From Scratch
2,161
59
7
Posted in TechnologySoldering
Introduction: Super-Easy Fume Extractor From Scratch
About: Hi friends, We are trying our best to provide you with the best Instructable experience.Our Instructables will be mostly on Arduino, Electronics, Budget builds and sometimes even Art!
Hi friends,
In this Instructable we'll be showing you how to build a Soldering Fume extractor mostly from waste
You can upgrade this one to use activated carbon filter. Thereby,This will not only suck the air away from you, but filter out some of the particulates from continuing to circulate in the room.
Do you need a soldering fume extractor?Is it bad to breathe in solder?
It is advisable to use a Fume extractor in order to protect your respiratory system.
All solder fumes can cause occupational asthma and other health problems (leaded and lead-free) if used for long periods at a time. The best solder wire contains something called Rosin that helps the solder flow when hot. This causes asthma if you are over exposed and is irreversible.
What health hazards are related to flux gases?
Studies have been made on workers in the electronic industry, mostly in the United States, and England. These studies show that at least 20% of the employees working in the soldering area show clinical symptoms of asthma caused by the work environment. These symptoms are characterized by coughing, shortness of breath, wheezing and chest pain. The conclusion of these studies is that Colophony fumes are the main cause of the illness and employee turnover in occupations related to soldering.
Step 1: Let's Acquire the Parts
We made this using the components lying around our house. So it didn't cost a cent to us
The parts:
• a fan - we salvaged it from an old oven
• a box
• a wire with suitable plug
• a Switch
• a strip of cardboard ( for ducting the fan)
• a filter- you can get a Carbon activated filter if you are a Pro
• a thick wire(for the grill)
• Some Velcro
Tools:
• a glue gun
• a soldering iron
• a screw driver
• a hobby knife
Just have a look at the Images, That will be fine
You need not go through the written part to understand this Instructable
Step 2: Start With the Box
In-order to keep the Exhaust intact,
We need to do some Modifications to the box:
  • Measure the Diameter of the Fan
  • and Cutout a circle from the Box
  • Make slots at the back of the box for the air to escape
  • Attach some Velcros inside the box for the filter
  • And Fix the filter
  • Adhere the switch to the Box
  • Also make a hole for the Wire
We've added the filter at the back of the fan to increase efficiency
We also tried this one by attaching the filter at the front in vain.
Step 3: Tinker the Exhaust
  • Duct the fan to arrest the leakage of air
  • You can do this by gluing a strip of cardboard around the fan
  • Solder one lead to the Wire and the other one to the Wire which has the Plug
The hardest part is done
Step 4: Establish Some Electrical Connections
  • Slide the Exhaust inside the Box
  • After making Sure that it is correctly sliding in, You can add a Grill for safety
  • And solder the wires(have a look at the pictures)
Just once again make sure the connections are intact
AC current is dangerous! be careful while handling them
Now you can connect it to the Power supply ( for us it is 240v)
And Keep up your soldering Spree
Share this with your friends So that they will get benefited from this
If you feel that this project was worth viewing or If it will help you;
Please vote for us in the contest if you like to support us
If you think that this project is not worth voting;
Please consider commenting so that we will be able to rectify our mistakes and create Better Instructables in the future
Your suggestions will help us evolve a lot.
You can Check out our other Instructables if you Wish
    • Microcontroller Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    7 Comments
    Wow that's great!
    Keep up with your Progress
    I'm going to try this. Thank you J
    Great idea and nice instructrions. Thanks :-)
    Awesome Instructable, Great way to upcycle useless electronics.
    Keep posting more of your Projects
    Sure, we'll be posting our other works in the near future
    We've used a normal air filter (spare filter of an old air purifier).It is basically a sheet of fine sponge
    Check "Step 2: 4th image" for filter
    However you may use a Carbon activated filter if you'll be soldering for long periods of time
