Super Easy Glasses Repair
I bought a pair of relatively expensive flexible frame glasses about a year and half ago.  I'm really rough on glasses which is why I splurged on the expensive but forgiving frames.  Sadly, I seem to have picked the wrong retailer and ended up with frames that looked nice but were very poor quality!
The first set of frames snapped right in the middle of the bridge about three months after I got them--still under warranty though!  The second pair snapped in the same place a couple of weeks ago, and I've been running around with broken glasses ever since.  I hate spending money on something like this, especially since the prescription is still fine and the lenses are in pretty good condition!
I've come up with a simple way to make these work until I've got a new pair, and I thought I'd share it with you all.
Step 1Materials and Tools
Materials and Tools
All you'll need materials-wise is your old pair of glasses (as long as the lenses are still good) and a pair cheap reading glasses from the dollar store.  Get the "Rimless" kind of reading glasses, where the bridge and arms are connected by screws drilled right through the lens.
For tools, you will need:
  • Mini screwdriver set
  • Dremel or drill
  • 1/16" drill bit
  • Fine tip sharpie or very sharp awl
35 comments
May 30, 2011. 9:45 AMPyRex says:
If you are using a dremel you may be going to fast. A slow speed is better for these types of themoplastics. To properly drill you should practice a few holes with a HSS drill bit, starting with about 350 rpm and playing with how much pressure you apply until you get long spiral chips. Once you can get these chips to form regularly you should be ready to drill you lenses without them fowling up the drill bit. I hope this helps!
Oct 27, 2010. 9:16 AMjoffler says:
This is a fair solution for folks without astigmatism but I'd caution against this for astigmats. I can tell you a lot of people have astigmatism and a lot of astigmats have no idea they have astigmatism. For astigmatism, the lenses must be rotated to the proper degree or "axis". Your Rx will have a prescription in algebraic form such that there will be a diopter value for "sherical", a diopter value for "cylinder" and a degree value for "axis". If your prescription only has values for "sherical" diopters, then this solution may work for you. Otherwise you're an astigmat and if the axis is off, this could result in distorted vision, an inability to focus, fatigue and headaches. For a quick and easy check to see if you've got astigmatism, take your glasses off, hold them in front of your face, focus on an object you can see through a lens and rotate the glasses clockwise or counterclockwise slowly. If the object you're focusing on begins to distort in shape, you're an astigmat. Be sure to check both lenses independently as some folks may have astigmatism in one eye only. For the record, I'm not a licensed optician but used to be one while going through college.
May 13, 2010. 3:42 PMmilltools says:
Dude you better watch yourself with that design. That came out in the late 70's by Mr. Navin R. Johnson , it's called the Opti-Grab.
Oct 14, 2010. 7:01 AMgerry_49 says:
LMAO That's all I could think of when I saw the glasses.
Good thing it's OK to copy a patent as long as one doesn't profit from it.....lol
Sep 11, 2010. 7:25 AMTankobu says:
Good fix. I was trying to match the my original lense shape to some cheap sunglass frames. It wasn't a perfect match...but I wasted $15 on this repair. I'll try this method. Thanks for sharing.
Aug 31, 2010. 2:49 AMfrostwirm says:
The Tucker car was too good, so he went out of business. I had some flexible frame glasses that had a flexible bridge,http://vediredan.narod.ru/mapa.html but they broke at the hinges
May 13, 2010. 5:25 PMlancelot says:
I tried using JB Weld... of course it's not for this type of thing.... Never thought of doing this.... but am heading to a Dollar Store soon!!  Thanks!!
May 16, 2010. 5:00 PMkedwa30 says:
 One reason why everything from Epoxy to solder wouldn't hold could be if the surface was not clean enough or was too smooth. Solution: sand the area with fine grit sandpaper and wipe it clean with a micro-fiber cloth. The dollar store has some good deals on micro-fiber cloths. I like the small ones that are two for a dollar.  Only expensive paper towels don't leave behind lint, but a dozen micro-fiber cloths can replace a year's worth of paper towels, saving you money as well as being nicer to the environment.
I wonder why the expensive flexible frame glasses wouldn't have the same flexible material for the bridge? Oh, I know why. Manufacturers design a weak point in all products. They need their products to break so you will have to buy more from someone. The Tucker car was too good, so he went out of business. I had some flexible frame glasses that had a flexible bridge, but they broke at the hinges. On the other hand, I've had a pair of nylon frame sunglasses since I was a kid (more than 25 years) that have been stepped on and abused, but they aren't broken! Go figure.
May 15, 2010. 1:37 AMVoltamps says:
 If you want really cheap glasses and don't mind the work you can buy two pair of very cheap glasses, one with the prescription lenses that match one eye and the other pair that match the other eye. Make sure the frames are both the same.  Take the left lens out of both pairs and put the left lens that is good for the left eye in the pair that has the good lens for the right eye. hey presto a good pair of really cheap glasses.
If you buy glasses that have the screw together lens holders, the only tool you will need is a jewellers screwdriver.
May 13, 2010. 3:51 PMsteliart says:
Very well documented Ible.
Thanks for sharing
May 13, 2010. 1:01 PMjules15 says:
sweet thanks, my glasses are getting pretty weak and will probably break soon so i'll have to do this
May 13, 2010. 12:03 PMAlej24601 says:
Mine broke in exactly the same place, and were also the flexy type...  Interesting.
Anyway, my solution was to use the clear part of a pen ink tube (The part above the ink, like out of a Bic), heat it a little so I could give it give it the right bend, fill with hot glue, and shove both ends of the bridge into it.  Worked a dream, and didn't require any modifications to the lenses or frame.
May 13, 2010. 5:20 AMexabopper says:
I did this once, except that I only used the bridge and not the temples, and I took off the little nose pads.  I then ended up with just the lenses fixed together without any other hardware.  Finally, I got some of those clear suction cups from a craft store, the kind that lets you hang little stained glass ornaments in a window, and affixed them to the bridge.  I stuck this whole assembly to the inside of my diving mask - instant prescription diving mask!  Dang, I need to make an 'ible about that one.
May 12, 2010. 6:43 PMtangent says:
 the easiest way to fix this would be to solder the pieces together as long as the frame was not made from titanium. all you need is a flame, stick of solder and a steady hand. also, after reading the comments about the 'cheap' glasses alternatives such as internet glasses all i have to say is you get what you pay for. they are an unregulated body and having an improperly pair of glasses can and will cause you all different kinds of problems. one of which is if your PD is off by only a few mm it can induce prism and make your glasses (which you got for a wicked deal btw) absolutely useless. just sayin'
tangent's optician wife
May 12, 2010. 3:20 PMDanYHKim says:
Some types of rimless glasses have a hole and a slot to hold the hardware in place.
May 12, 2010. 3:23 PMDanYHKim says:
Be careful when you are bending the frame metal.  If you hold the lenses while bending the metal, they may crack, since it puts a lot of stress on the small bit of plastic that surrounds the screw hole.
Better to use small needle-nose pliers or hemostats to hold only the metal components while bending.
May 12, 2010. 3:25 PMDanYHKim says:
I have had trouble drilling into polycarbonate lenses.  Your advice to use an awl to make a starting point is very good.  My drill tended to melt the plastic, rather than cutting it.  This made for an awkward hole, and the drill bit was coated with hardened plastic.
I wonder if the drilling could be done under water to keep things cool?
May 12, 2010. 4:29 AMmrmath says:
If you know your prescription and Pupilary Distance, you can get good glasses super cheap online at www.zennioptical.com.  I have nothing to do with the website, and make no money by posting this link. Just giving you a heads up on a cheap alternative.
At the very least, you can buy 10 pairs of frames for the same price as retail, have the lenses put in locally, and then move the lenses over when the glasses break on you.
May 12, 2010. 10:21 AMmrmath says:
Just had another thought.  If you didn't drill through it in this instructable, your lenses actually have the prescription in them.  You might be able to take it to an eye place and ask them to just write down your current prescription. Not give you a new one, but just write down what you currently have.
The beauty of zenni is that they are not in the US, and therefore don't require a prescription.  If you know what you have, you can order exactly that.
May 12, 2010. 7:10 AMmrmath says:
If you've got insurance, you should be able to get an eye exam pretty cheap. $20 or so. My coverage, however sucks. My daughter's exam cost me $50 yesterday.
May 12, 2010. 9:13 AMTool Using Animal says:
I'll second the Zenni optical solution, love my glasses....
For eye exams, shop around,  Sam's Club is cheap, and you don't need to be a member.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
287
Author:depotdevoid(depotdevoid on Facebook!)
Like me on Facebook, my poor, fragile ego needs a boost! I post updates about my current projects, and the occasional sneak peak at upcoming instructables! ...
more »
