loading
loading
Easy, Reversible Motor Control for Arduino (or any Microcontroller)
Featured
Picture of Easy, Reversible Motor Control for Arduino (or any Microcontroller)
This project uses just three main components to provide forward and reverse control for a single motor.  You can easily interface it to an Arduino or any other microcontroller.
It's so simple - you can wire it up "free-form" without a circuit board in about 15 minutes.
Features:
All parts available at Radio Shack for under $9
Supports PWM for variable speed control
Handles up to 5 amps peak / 2.5 amps continuous (5 amps continuous with heatsink)
Controlled using just two pins - "enable" and "direction"
Limitations:
Requires at least 7.5 volts to operate
Relay is rated for "only" 100,000 cycles and may not be appropriate for some high vibration projects
Doesn't provide motor "braking"
The most common way to provide reversible motor control is with an H-Bridge.  A basic H-Bridge is made up of 4 transistors - but commonly end up requiring more like 10 components when you include things like flyback diodes and secondary transistors.
I wanted something simpler for a CNC project I'm working on - so I came up with this design.  I'm fairly sure I'm not the "inventor" of this circuit - but it's not widely documented.  As far as I can tell it doesn't have a name.
I am hereby naming it the RAT Controller.  RAT being an acronym for Relay And Transistors.
1-40 of 105Next »
AndrewS12 made it!yesterday
Great instructable. I used 3 of them to control a robot for a local science fair yesterday and the circuits worked great. The robot worked continuously for 4.5 hours without fail. I am planning on using a similar circuit for a summer camp. I was wondering about the value of diodes to limit surge voltage from the inductors? Anyone have any thoughts?
deuchar1 month ago
Hey guys I have been able to control the motor speed and halt. But I am not able to change the direction I am using this relay http://www.futureelectronics.com/en/technologies/e...
Kindly help.
bennetta3 months ago
hey, i hav built a circuit to control 3 dc motors using icl293d , the operations include forward, reverse and speed control. the code works fine when motors are connected separately, but when powered together, it just stops in between and the resets the program.please help.
nothinglabs (author)  bennetta3 months ago
It might sound obvious - but I'd make sure you don't have any shorts.
If you're trying to run all the motors at once - it might be overtaxing your power supply and causing a brown-out.
Good luck!
-Rich
427hotrod3 months ago
im trying to make a east speed control for a small dc motor i dont want to use a h brige simpllifying the design im trying to use a volume control but seems to not work anything i should try using for a control or is it fine i dont want to use an h bride thats the thing
JasonK64 months ago
I have built the exact circuit you have, same parts. I wired it up and hooked it up to a motor. The motor immediately turned on as the 12v clicked the relay, it seems like the arduino is doing nothing to the circuit. Volt meter shows the arduino sending signal but the relay isn't switching back. I think the enable transistor is shot, unknown. Thoughts?
nothinglabs (author)  JasonK64 months ago
I would triple-check all wiring - and verify you're using the same model of relay.
It's possible the enable transistor is shot - but the darlingtons are pretty sturdy...
Nazih4 months ago
Hi, I am planning to build one for a moving santa going up and down on a rope using a 12 volt DC electric motor, could the reverse action of the motor be set to a certain timings (say 2 min) after which the motor will automatically reverse the rotation, for un limited period, until it is shut off? Regards, Nazih
nothinglabs (author)  Nazih4 months ago
as long as you use a microcontroller (like arduino) - you can do pretty much whatever you want.
good luck!
nothinglabs (author) 5 months ago
So - not totally following what you're trying to do. I think if you're using a i-o-ii type switch with two poles (probably 6-pins total) - that might be enough to do forward / reverse / off on a motor..
Hi,
I am not too clued up on this sort of thing but I will be making one of these to control the opening and closing of a drawer using a threaded rod and nut, although, I will only be using a 'I-O-II' switch. I assume I would replace that piece of kit for the 'I-O-II' switch? And I assume that 'I' will go forward 'O' will kill it and 'II' will reverse if I use this same setup?
Thanks
jason5316 months ago
Thanks for this. I was looking for an inexpensive H-bridge I could make from locally-available parts.
I am new to this type of thing, so forgive me if this is a naive question. If you were only interested in on/off and not PWM, couldn't you use the "enable" pin to drive the coil on an SPST relay which would then connect ground the common pin on the DPDT relay? That way you would only be driving the coils (your DPDT only uses 60ma) and would only be limited by the max current of the relays themselves. The TIP120s should be able to handle just about any size relay (RS sells a 10A DPDT with a coil rating of only 130mA).
I am asking because I want to use an old cordless drill and I've read that those things can pull over 100A! Thanks again for posting this guide.
nothinglabs (author)  jason5316 months ago
Sorry for slow response.
Yes - I suspect you can add an additional relay after the "enable" TIP120 - and then use it to drive as large a load as it can handle.
Sounds like a good idea if you're not interested in PWM. You might even be able to do very slow / loud PWM - not sure how long that would last though...
Have fun!
-Rich
What would you need to add or do to make the motor go faster forwards and backwards and have a manual mode and auto - mode for 30 seconds involved into the circuit?
gcarter510 months ago
This is absolutely brilliant Thanks a bunch for awesome instructions. its exactly what i was looking for as h bridges keep over heating and cooking my BD135 NPN transistors. I owe you a beer. Cheers
nothinglabs (author)  gcarter510 months ago
Happy to be of service!
atai071 year ago
hello .. I have tried your circuit but the motor only moves in one direction only .. the delay is still there ... but I still hear the sound Click on the relay ..
so where is my mistake ... can you explain
I use tip 122 ..
relay as you use
batery 12 v 1.2 AH
plz help me ...
tq
nothinglabs (author)  atai071 year ago
If the relay is engaging - but the motor direction isn't changing - I would triple-check how you have the relay wired. (assuming you're using the same kind of relay as described)
Good luck!
-Rich
Can I connect two motors to the pins of relay instead of one for my project
or I need to make two similar circuits?
and, any other 6v relay should work fine, should nt it?
It worked pretty well until I burned it up. :)
Hi, i stumbled uppon a problem. I can hear my relay switch but when i hook up a 6/9v dc motor to it my motor doesn't turn. I'm using 7.4v.
nothinglabs (author)  ArthurCornelis1 year ago
The relay is only used to switch the direction of the motor - as opposed to actually toggling the power.
The tip120 connected to the "enable" pin is responsible for toggling the actual power - so I'd start troubleshooting there.
Good luck!
-Rich
zhungu1 year ago
Hello again. is there a way it can be modified to have "brake"?
nothinglabs (author)  zhungu1 year ago
Maybe.
I think typically motor controllers "brake" by shorting the motor leads. I don't think that's possible with this setup.
However - you could try quickly toggling the direction pin (maybe 20hz - 40hz) - and then doing some level of PWM on the enable pin.
Can't say if this will work - but it might. It will certainly make some noise though - and might not be very "nice" to the various components...
zhungu1 year ago
Hie. would this relay work as well? How do i know which ones are the normally open, normally closed pins and so on? Thanks
http://www.jaycar.com.au/productView.asp?ID=SY4065
I believe that relay would work assuming you provide the needed voltage.
I would suspect there is some indication on what pins do what on the relay itself. Otherwise - I might just experiment using a multimeter.
crob091 year ago
Hope you don't mind the question but I'm wondering how this circuit could be used to control a high power device, it looks like the 12V-power charges the relay coil and drives the motor, I maybe wrong but is there a way to connect another power source to drive say a 36VDC motor?
Thanks for any help,
nothinglabs (author)  crob091 year ago
Should be able to - just find a DPDT relay and "drive" darlington of the values you need.
The darlington that triggers the relay can probably stay a tip 120.
On this page I mention I higher power darlington option:
http://www.nothinglabs.com/openmelt/
(the solid state relay on that page might also be of interest)
-Rich
That link takes me to an awesome project thanks!!
Maybe I'm confused about the Relay, I notice they have two values one for the coil (I think) and the other for the max load, will the Max-load value work for the coil too, for example below the relay is rated at DC5V 28VDC?
Sorry I really don't see how I connect a higher voltage to this, My relays are "JQC-3F(T73) DC 5V 5PIN 250VAC 28VDC Power Relay"
I suppose this won't work also because of them being five pin opposed to six?
For this project you'll want DPDT relays - which I don't think those are.
Good summary on what this means here:
http://en.wikipedia.org/wiki/Relay
Relays are commonly rated at a voltage / current required to engage (you can usually go somewhat higher or lower) - and the maximum voltage / current it can switch (often different for AC and DC).
-Rich
Cool I've ordered some of the DPDT relays and the proper voltage.
Thank you for the summary link, you're right it has tones of good information.
Also thank you for the reply to my question and great job on the Tutorial.
Is it alright if I post something like this on my MOSFET page on electric-canada.com?
Good luck with the build.
Please feel free to use / share any aspect of this instructable however you like!
Ohh yeah one more thing I was looking at your website and the Arduino Laser show is awesome!!!!
http://www.nothinglabs.com/laser/
TomDunlap1 year ago
Just finished a prototype of this to run the motor for the solar forge I'm building. Here is a clip of it running a re-purposed Skil cordless drill:
nothinglabs (author)  TomDunlap1 year ago
nice!
RISL2 years ago
hello friend i have a question about your proyect and it is posible to use with a step direction 3d printer, the 3d printer use an arduino but is the only thing i need or is necesary a interpreter, i use a sprinter firmware, i need some change or only i have to conect direct.
nothinglabs (author)  RISL2 years ago
it should be able to drive any standard DC motor.
Not totally sure - but your printer may user stepper motors - which won't work with this project.
saip2 years ago
i dont understand all this circuit connections....can u suggest me any website where i could learn about all this stuff.......plz help me.................
itshuang2 years ago
Thanks for your suggestion. I found a wiring that might work for my need: http://www.quasarelectronics.co.uk/kit-files/help-files/uhf-remote-control-reversible-dc-motor-with-limit-switches.pdf
If I use the forward and reverse leads (2.5~3v) to activate the top and bottom relays (e.g a SPDT relay, such as this one: http://www.mdfly.com/index.php?main_page=product_info&products_id=444) respectively, and power(+) connected to the top NC, and power(-) to the bottom NO, do you think it will work? I appreciate your comments to a newbie like me.
itshuang2 years ago
While I am searching for ways to make my high torque DC motor reversible, I came across this instructable. It is amazing. What I am trying to do is to use a RC car's Transmitter(Tx)/Receiver(Rx) to control my DC motor's rotation(forward/reverse). The outputs from the Rx are one forward and one reverse which may be "high" depending on what is triggered on the Tx side. It works for low power DC motors. However, it is too weak to drive a high torque motor. So I need to get extra power to drive my motor reversibly. Is this control can be modified in some way to meet my need if I use the outputs from Rx as triggering signals (Say forward connects to one transistor and reverse links to another transistor)?
1-40 of 105Next »
