Ever feel like you're missing some beats? Does your day need a better soundtrack? Feel the boom with the Super GrooveAxe! It's a pocket sized, battery powered drum machine & sequencer that you can take anywhere. It makes every moment special.
The Super GrooveAxe is available as a kit on Gadget Gangster.
Here's a demo:
Remove these ads by
Signing UpStep 1FAQ
The Super GrooveAxe is a mini drum machine / sequencer. 4 sounds are available, and the playback speed of the pattern can be controlled.
How do I use it?
There's a switch on the Battery Box, flip it on. The Red light will start blinking about every 1/4 second. Push one of the 4 sound samples, and you'll hear it play. The sample will repeat, and you you can layer on the other samples with each repetition to build up a complex pattern. The replay speed of the pattern can be controlled with the tempo button; push it once to change the tempo. Wait for as long as you'd like the tempo to last, and hit it again. Your pattern will now play with the new tempo.
Where does the sound come out?
Sound comes out from the 3.5mm Audio jack on the top center. You can plug it directly into headphones or to another amp / input with a dubbing cable.
How long do the batteries last?
I haven't been patient enough to run the batteries all the way down, but I'd estimate around 30 hours of play time. It runs on 3xAA's.
Is it hard to put together?
NO! In fact, it makes a great first-time project. If you've soldered stuff before, it will take you about 20 minutes to put together, a little more if this is your first time.
The sound comes out of the 3.5mm headphone jack.
How big is it?
The GrooveAxe will fit in your hand, it's about 4" x 1".
The original GrooveAxe was designed by Grandtippler - he has re-done the audio samples and I designed the PCB for this improved version. A kit or bare PCB are available on Gadget Gangster.
What's wrong with Susan B. Anthony? Don't like suffrage?
How easy is it to alter the sounds? Are there plans for a version with a programming connection for the PicAXE?
As for re-programming, I decided not to include a programming jack to keep the size down, but the chip is socketed, so it's easy to pull out and reprogram.
If you're familiar with the picaxe, changing the sounds isn't that hard (Grandtippler's code is on the last page of the instructable), the sounds are defined at the end of the code. It is hard, though, to get interesting sounds. I think that takes a lot of experimentation. And to re-program, you'll need a programming cable
I stand by my question, and expect a video in the near future: BohemianRhapsodyAxe!
He also did the MemAxe, but that's more of a musical 'simon says' game.
i mainly use arduino stuff , custom boards mainly cos its cheaper to make my own XD.
wouldn't mind trying this out if i can source the chips cheap xD
You can get the PICaxe from sparkfun - I think an 08M is $5, and the programming cable is $25. I've also started playing with the kic chip, which is a freeware version of the PICaxe. There's more info on the Kic here.
For me, I use a Propeller when the project has advanced requirements, and a PICaxe when I just need basic logic.
how hard do u think it would be to build an arduino version of this using an atmega168 or 328?
This project uses a PICaxe for size (only 8 pins) and cost (a PICaxe 08M is $5 and just needs a single resistor to run). There are plenty of other uControllers that would meet those requirements, though.
