Step 7Super IPod : How to connect fabric switches to hacked mp3 player
Now you have five soft fabric switches. Mark the position of the switch using the IPod template. Set the position of the switch on the dial inside the pillow and glue the switch using the fabric glue. Now take the mp3 player base, which has 12 snaps on it, and attach it to the bottom using the fabric glue.
2. Attach a red LED, bend its wires, and sew it
To indicate the mp3 player is working, we will attach the LED on the window of the IPod. Make a little hole down the left side of the window and attach the LED using fabric glue. Mark (+) and (-) on the fabric to indicate which is the long leg for the positive connection and which is the short leg for the negative connection. Bend the legs of LED and sew the legs using conductive thread.
3. Connect snaps to switches and sew them together
You have a few handmade felt wires. If you buy the kit, you can find them inside the kit. If you want to make them by yourself, check the "How to make fabric wires". It is very easy to make them with conductive fabric and felt. With these felt wires, connect the snaps to the switches. Cut a little bit in the middle of one side of the felt wires. Sew the divided edge to each conductive fabric wing of the switch. Sew the other side of the wires to snaps on the mp3 player base.
Fellow the illustrated instruction to attach switches and snaps.
http://itp.nyu.edu/%7Ejsl398/DIY/img/instruction_ipod81.jpg
Tip: Check the continuity
When you done to connect switch and snaps on the base, you can check the it works or not using multi-meter. When you press the switch connected to the snaps, you should see the result of continuity.
4. Attach mp3 player to the base
Close the snaps of the MP3 player to the base of the MP3 player. The snaps will allow you to detach the mp3 player whenever you want. When you wash the pillowcase you should detach the mp3 player from it.
5. Hook a headphone or speaker to mp3 player
Turn over the pillowcase. Hook a headphone or speaker to an mp3 player. When you press the button, you can see the indicator on the window changes.
Add Comment
