Super Laptop Chillpad
Introduction: Super Laptop Chillpad
Through the use of resources I have and parts I've obtained. I'm making a 17" laptop chillpad. The heart and soul of the chiller is the cooling fan out of PS3! This 12V 2.65 Amp fan can pull some mean air. Through the use of a CAD program and some spare time I had, I designed a fairly basic pad and I'm getting it milled out.
Step 1: Obtaining the Parts
A buddy of mine had a PS3 that crapped out on him and was out of the warranty. So what was the most logical thing to do? take it apart of course. After taring it apart, I found it necessary to keep the fan for this such kind of project.
Step 2: The Design Process
The following are the CAD designed drawings. The design I came up with allows the pad to sit on my lap and directs the air flow out the back and sides away from me. That way there isn't and hot air being directed back towards me. If I had used a normal PC fan, the air would still be directed right into my lap and I'd have to elevate the pad to allow the airflow to dissipate. My design, elevation isn't necessary.
Step 3: Power Source
The power source for the 140mm fan it going to be a 9V 2.2A power pack. Though its not rated for the fan (12V 2.65A) it still has enough power for this project. My plan is to install a potentiometer / rheostat to be able to control the speed of the fan. Through testing the fan to see if it worked, I found it has far more suction then expected (awesome)
*I have recently added an air scoop to my design so extra air flow will be forced into the internal laptop CPU fan. Since the PS3 fan has far more suction than i originally anticipated, I'm putting some weather stripping on the chill pad to segregate the air flow, that way the PS3 fan doesn't rob the laptop of its natural airflow.
**I'll add the newly updates CAD drawings soon.
    • Pocket-Sized Contest
    • Science of Cooking
      Science of Cooking
    • Pro Tips Challenge
      Pro Tips Challenge
    This is a great Instructable, but you need to add a main image of the final project to the intro step. Please do that and leave me a message when you have so that we can publish your work. Thanks!
    I've built a prototype out of 1/4" cardboard and it works just fine. The rubber feet on my laptop has enough clearance to suck air in from all directions. Matter of fact it works so well that the top of the laptop gets cold as well. The PS3 fan has more than enough suction power to get the job done.
    hey man, I wonder what if anything u would charge to make one of these for me, minus the fan of course, Id add that myself :D
    very interesting...i was planning on making something like this but all i have is a working have one of the original ps2's (you know, the big boxy ones) and i ripped out the cooling fan from that. anyone have any ideas or links to ideas as to how i could connect a power pack to that or if i could hook that up to a usb port and not have it blow up in my lap? lol
    that's not a proper design. you need risers for the laptop to sit on. my cooling plate restricts "breathing" and actually raises the temperature by 5 C. My laptop performs at around 77 C under normal conditions, and it has rubber risers with dual high-rpm fans. also, seems a bit pricey. :P
    mine doesn't need risers since the air flow is directed horizontally instead on straight down into the table or my lap. thats the beauty of it. Testing it out with my laptop running full speed  (both cores of the processor maxed out on high performance) the pad colled it down as much as 30 F (give or take 10 C).
    I have a PS3 fan as well that I stole out of a non-working PS3. My question is how did you wire it to the power pack?. I have a 12V 2A  AC/DC adapter I thought i could use but had no luck splicing it to work with the PS3 fan. Any tips appreciated.
    I'm just curious on how noisy the ps3 fan is.
    Well to be honest, the 1st 18 mins, it's fairly loud. Since I'm not using the circuitry that's in the PS3, the fan runs at full speed (well almost, the power pack I have isn't quite as powerful as the PS3 but it runs at about 80% of full power). After the 18 min. pass, the circuits in the fan kick in and slow down to near silence while still having a decent amount of air flow. As far as I can tell, the fan has a built in heat sensor, so if I have it running for a while and unplug it for like an hour, it'll run full speed again and the 18 min. resets.
    If you reverse the power to the internal fans so they spin backwards, put ice in front of it, you got a good chiller.
