Introduction: Super Mario Bros. Mini Mushrooms
Mini marshmallow mushrooms with red and green candy tops.
While tootling down the soda aisle to pick some root beer, I discovered this cool ice cube container. The bottom part is rubber, so you can easily pop out the ice cubes. I picked it up and figured I would figure out a good use for it. It came to me a few days later – mini Super Mario Brothers mushrooms!
Ingredients:
Red candy melts
Green candy melts
White sprinkles, round (I used Spring Confetti from Wilton)
Chocolate Sprinkles
Equipment:
Ice cube container with rubber bottom
Sealable plastic bags
Toothpicks
Step 1: Melt the Candy Melts
Take a 1/4 cup of green candy melts and place into a plastic bag. Microwave for 20 seconds, moosh them around, then repeat until they are fully melted.
Step 2: Pour Candy in Container
Snip off a corner of the bag and squeeze the candy melts into the compartments of the ice cube container. You’ll want them no higher than 1/2″; between 1/4″ and 1/2″ is best.
Step 3: Add Mini Marshmallow Stem
Next, pick out your most stable marshmallows. I would set one on the counter before adding it to the candy melt. If it stood up, I added it to the candy melt. Gently press in the marshmallow. It doesn’t need to go in far t’all.
Allow the candy melts to sit for an hour.
When they’re set, pop out the candy melts. Careful when popping these out – one hit me right in the noggin! I could’ve been killed.
Step 4: Seperate White Sprinkles
If you don't have just white round sprinkles, separate out the white sprinkles from the rest of the colors. You'll want to have the sprinkles ready right after the next step, so it's best to do the sorting now. If you just have white sprinkles, well, then you're just on the right track.
Step 5: Dip the Candy Tops and Add White Sprinkles
You’ll note that the rubber tip of the ice cub container will have colored the candy melt differently – it’ll be a notable lighter red or green color. So, we’ll need to dip the top in more candy melt to even things out.
Take 1/4 cup of the candy melts and microwave for 20 seconds, stir, and repeat until the candy is fully melted. Dip in a mushroom and shake off the excess candy.
Add white sprinkles to the tops of the mushrooms! I wasn’t able to take pictures for this bit since it’s a two-handed operation.
Step 6: Allow the Mushrooms to Rest
Allow to dry. I found that a cooling rack worked out peachy.
Step 7:
Finally, take a tooth pick and etch in the marshmallow where you would like to place the chocolate sprinkles. Push the chocolate sprinkles into the marshmallow.
Step 8: Enjoy!
Repeat adding the chocolate sprinkles for all mushrooms and you’re done!
