Super Mega Barrage RBG! #2
1,155
5
6
Published
Introduction: Super Mega Barrage RBG! #2
Beefed and tested, its back, powerful, stronger, accurate and you want to build it.
Fires unlimited rounds in one shot with pinpoint accuracy and long distance range.
Uses same new (world first i hope) trigger mechanism as in ver1 which enables firing barrage of rubber bands in one shot.
Step 1: Firing Mechanism and Trigger Part 1
How to build the firing mechanism and trigger part 1.
Just build what you see:
Pic 1 - build these different parts you are going to be using in the trigger mechanism.
Pic 2 - this is the essential part in the mechanism build this.
Pic 3 - (the same part as in pic2) slide the white piece up to the brown part to trap the rubber band.
Pic 4 - on the other end of the same piece, do the same thing
Step 2: Firing Mechanism and Trigger Part 2
How the bits you made in the last step fit together
select the parts you can see on the image and put them together to look like the image
Step 3: The Grip
How to make the grip.
pic 1 - make these bits
pic 2 - put them together to look like this
pic 3 - how it fits on the firing mechanism
Step 4: The Stock
How to make the stock.
Pic 1 - make these bits
Pic 2 - snap the green bits into the right place
Pic 3 - where the other blue rods go
Pic 4 - how it fits on to the body
Step 5: The Barrel
How to make the barrel:last step and then you're done!
Pic 2 - where to snap the blue rods in place
Pic 3+4 - where the end of the barrel goes
Pic 5 - how the barrel fits on the firing mechanism
Step 6: Loading and Firing
How to load and fire.
Hook the rubber band on the front yellow bit at the end of the barrel and on one of the white pegs on the wheel to load.
Simply pull the trigger to unleash the stream of rubberbands should you choose to take advantage of the unlimited ammo feature.
If you have any questions, drop me a comment or send me an e-mail at ibborox@hotmail.com
Have Fun!
    • Oil Contest
      Oil Contest
    • Creative Misuse Contest
    • Stick It! Contest
      Stick It! Contest
    6 Discussions
    my rubber band gun i made is a lot more stronger than this instead of using rods try linking lots of connecter to make the barrel
    Technically it aint unlimited because theres a point in which the white rod will break off the snow flake
    nvm didnt want to. also this isnt technacly unlimited rubber bands
    there are more than 1 rod on the snowflake. Yes there is a point where it will selfdestruct but I dont have enough rubber bands to test how many it will hold and I have only been using thin ones.
