Get the Infrared LED's for this Project HERE
Remove these ads by
Signing UpStep 1What You Need...
Remove these ads by
Signing Up| « Previous Step | Download PDFView All Steps | Next Step » |
All Steps Viewing
a have a viewfinder with 4 yellow wires and 1 black wire. how do i find out which one is video and power?
-please shed some light for me.
I made this project a while back, just without the camera and view finder part.
It works very well!
I would like to make a 2 or 3 led of this, so I can see in the dark with my mobile.
I can see the led butt they are very weak.
How is this possible?
What must I do?
THANK you for your help!
If you want to see the infrared better you will have to remove that filter but this is quite a hard job.
There are various things you can do (Zeners, DC-DC converters etc) but by far the simplest, although not the most efficient, is a 7805. For a project such as this I would not consider anything else, but as rocketman said, you will probably need a heatsink.
I can give you my phone number and maybe someone can walk me through figuring this out.
Colors of the wires are as follows:
Pin 1 Small yellow
Pin 2 Med Black
Pin 3 Sm Grey or white
Pin 4 Sm orange
Pins 2+3 share a heat shrink "sleeve" while 1 and 4 are "loose"
http://www.amazon.com/SC-NVA5-Wired-Security-Camera-Adapter/dp/B000V0AHRA
http://www.lucidscience.com/pro-night%20vision%20viewer-2.aspx
http://www.lucidscience.com/pro-night%20vision%20viewer-3.aspx
They tell how to do it all.
http://www.lucidscience.com/pro-night%20vision%20viewer-1.aspx
It should solve any further questions
2 viewfinders and 2 cameras that are positioned like your eyes are in your head would give you the advantage of still being able to judge distances, which 1 cam and viewfinder robs you of.
Onto the idea of welding goggles, that's exactly what I intend to use, as it already has the flip up/down support, it's comfortable (to an extent), and is dirt cheap.
With the amount of LEDs, you could use less, with I higher mW output, or, alternatively, less LEDs that have a angle of divergence, so that the beam spreads less over distance. You may also be able to make/buy a lens that can attach to the LEDs and focus them for a wide area or long, thin beam.
Several LEDs like this, with some adjusted for wide angle, and some for long distance would be ideal I imagine, as you'd have the best of both worlds.
And I'm not sure if it's been mentioned yet or not, but KipKay didn't come up with this idea. It was published years ago in the book "101 Gadgets for the Evil Genius", and it describes it in more detail there. I highly recommend this book, as it has several other projects of a similar nature aswell, and is a rather good introduction to working with IR.
Hope your nightvision goggles work well!
-Archive555
