This personalized candle holder displays a silhouette of my family on the wall and some text on a table using only the light from a little tiny votive candle. If done correctly, the shadow will be indifferent to the specific height of the wick and flame (within the typical sizes for votive candles that is).
Instead of hanging a photo with nails, or a mural with wallpaper/paint, the candle holder...and thus the shadow, can be swapped out easily for different occasions, even during the daytime hours!
Suggestions:
Also note that I rely heavily on annotating my images in this instructable since the easiest way to see what I’m doing is with a screen capture (Shift-Command-3), upload, and click for an instant note. Except for a few rarities, every image is tagged somewhere, so if you see a blank one, look for a itsy square crammed at the top of the image. Sometimes, I see this happening on both mine and other’s ‘ibles and I don’t know why. Clicking on the next image and then going back sometimes repairs the problem.
My system:
Parallels 7 running Windows 8 (AutoDesk is working on a Mac Version of 123D, but not yet out)
Remove these ads by
Signing UpStep 1: Decide on an environment for your shadow
The lighting and environment all need to be thought through and will determine the form of shadows that you can create.
You are not limited to a single surface. Actually, you can project a shadow through multiple rooms in your house that only makes sense from one perspective if you like (example: http://www.archivenue.com/wp-content/uploads/Geometric-Illusionary-Perspective-Paintings-1.jpg). Cast it on the ceiling, or both the table and wall simultaneously as I did.
Consider permanent obstacles, such as the chair in my photo...or dynamic ones, such as a person if they happen to sit in said chair.
Visit Our Store »
Go Pro Today »
I could explain away this issue with candle convection transport, effective surface area to volume ratios, or emissivity of the plastic, but thats just silly when I can say one way or the other when it gets here. -Jason
What was shipped to me was ineffective because of improper packaging (1/4 of the posts were broken), incomplete cleaning (support material was still surrounding many of the posts), and poor printing (in both resolution and the fact that the posts were curved!).
My busy work life has hindered having alternative high-end printing services from attempting better.
And wouldnât it be easier if the candle was taller shining down on the table?
I actually attempted individually curved features at first, but wanted to explore arrays and didnât consider patterns of hoops. I like that thought.
For your second question: Sharper angles are better and a taller candle would provide that when projecting on the table. However, I was concerned about the candle shrinking so significantly that I would loose the light contrast completely. Votives were simpler for me, thats all...and cheap.
I hear you. I has been clearly printed, but I’m awaiting delivery. They had to make several attempts because of technical problems on their end. They took a picture of it before placing it in the mail so that I would at least have SOMETHING to show. Thanks for your interest
Is there an actual picture of the stand in use and throwing a shadow?
