Step 9Install the Analog Controllers.
Grab your four Atari controllers and open them up with a philips screwdriver. (there are just two screws)
Take off the back cover and you will find a button and potentiometer inside. De-solder the wires from the potentiometer, unscrew the potentiometer and remove it from it's housing. (see second photo)
Repeat this for the remaining three controllers.
Now we need to drill some holes to mount these potentiometers into. (The third photo explains it all)
Once you have your holes drilled, you will want to mount your potentiometers in the holes and glue in place with some hot melt glue. Do this for all four potentiometers. (see fourth photo)
Once they are in place, you need to solder three wires to each.If we use the potentiometer nearest the circuit board as a reference: (see fifth photo)
- Top connection = +5v
- Middle Connection = player connection
- Bottom Connection = Ground
Anyway, If you then follow these connections around to the bottom potentiometer, we now have:
- Left connection = +5v
- Middle connection = player connection
- Right connection = Ground
You then need to connect the potentiometers to the circuit board. They are labelled on the board so it quite straight forward. (see fifth and sixth photo's)
And once all of that is done, you can now install your control knobs to the top side of the table. (see seventh photo)
So to save money, you can certainly go out and purchase the cheapest pots you can find = )
