3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Super Simple Beginners Robot!
Step 16Source Code
Source Code
UPDATED 2/16/09
SOURCE CODE FOR THE SONAR OPTION IN THE NEXT STEP (SPECIAL STUFF)
Follow the directions for your microcontroller and cut and paste this code into the editor. Compile and send to the robot.
The code is ultra simple but the bot avoids most obstacles it sees. It is easy to take my code and expand upon it.
'SuperSimpleBeginnersRobot
'www.instructables.com
'Ted Macy
'ted@oobug.com
'2/16/09
' Create and Setup Objects
Dim Servo_Right As New oServo
Dim Servo_Left As New oServo
Dim SRF04Servo As New oServo
Dim GP2D12 As oIRRange(3,8,cvOn)
Dim SRF04 As oSonarDV(8,9,cvOn)
SRF04Servo.IOLine=29 'Set the servo to use I/O Line 30.
SRF04Servo.Center=28 'Set the servos center to 28. (see manual)
SRF04Servo.Operate=cvTrue 'Last thing to do, Turn the Servo on.
Servo_Right.IOLine = 30 'Set the servo to use I/O Line 30.
Servo_Right.Center = 28 'Set the servos center to 28. (see manual)
Servo_Right.Operate =cvTrue 'Last thing to do, Turn the Servo on.
Servo_Left.IOLine = 31 'Set the servo to use I/O Line 31.
Servo_Left.Center = 28 'Set the servos center to 28. (see manual)
Servo_Left.Operate =cvTrue 'Last thing to do, Turn the Servo on.
' End Create and Setup Objects
' Main routine is your primary routine called upon power up!
Sub main()
Do
Call IR
Call Forward_All
Call SServo
Loop
End Sub
' End of Main routine
' Start of Drive System Subroutines
Sub Spin_Left()
Servo_Left.Invert=0
Servo_Left = 62
Servo_Right = 60
End Sub
Sub Spin_Right()
Servo_Right.Invert=1
Servo_Left = 62
Servo_Right = 60
End Sub
Sub Forward_All()
Servo_Right.Invert=0
Servo_Left.Invert=1
Servo_Right = 60
Servo_Left = 62
End Sub
Sub REVERSE()
Servo_Left.Invert=0
Servo_Right = 60
Servo_Left = 62
End Sub
Sub STOP()
Servo_Left = 0
Servo_Right = 0
Call SServo
End Sub
' End of Drive System Subroutines
' Start of Sensor Subroutines
Sub SServo()
SRF04Servo.Position=15
SRF04.Operate.Pulse(1,1,250)
If SRF04.Value<128 Then
Call Spin_Right
Else Call Forward_All
End If
ooPIC.Delay=600
SRF04Servo.Position=31
If SRF04.Value<64 Then
Call REVERSE
End If
ooPIC.Delay=600
SRF04Servo.Position=46
Call Spin_Left
End If
ooPIC.Delay=600
Call REVERSE
End If
ooPIC.Delay=600
End Sub
Sub IR()
If GP2D12.Value<64 Then
Call STOP
End If
End Sub
' End of Sensor Subroutines
3 comments
Apr 27, 2009. 2:33 PMredcars101 says:
How do I put the code in the robot?
Apr 12, 2009. 12:36 AMRohit Bag says:
which software should i use to write the program???
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
24
Author:BIGBUG(BABBLEBOT)
Evil, Mad, Nerdy Robotics Experimenter!
