3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Super Simple Cardboard Table
This is a really easy project and you may already have the materials lying around the house.
The table is lightweight, fairly study, and useful for putting things on.
And when you don't need it anymore, you can recycle it!
Step 1
Things you need:
1 box, the right size to be the top of the table. I'm using a flat box that I think was originally part of the packaging for a laptop computer.
4 mailing tubes. The length of the tubes will be the height of the table. (The diameter doesn't matter too much.)
Some sticky-backed plastic, and/or anything else you want to decorate your table with. Plastic is good because it will prevent the table top from disintegrating if you spill a drink on it. You may like to put clear plastic over a collage or a painted picture, in which case you will need materials for that.
You will also need glue, tape, a pen or pencil, and a utility knife.
7 comments
May 6, 2010. 11:29 PMmehyay says:
nice design. i am just wondering,
how much weight can it hold?
Mar 23, 2011. 9:14 AMwhisperonthewind says:
If you used the tubes from plotter paper, it would hold just about anything, but generally the ones I've used at work are 36" long. You would have to shorten them for a table like this, but the one by wholman uses angles and may use them full length. They might come in shorter lengths but I've only seen the 36"
Oct 29, 2010. 6:45 AMuberdum05 says:
Drill holes in the tubes every inch or so and put holes in the table top and then you can adjust the height of the table by taking out the bolt from every pole, lowering it, then putting the bolt back in :)
Sep 24, 2009. 7:28 AM323maderas says:
If you glue some 2 inch or 3 inch triangles against the legs and the bottom of the table it should strengthen it quite a bit
Jun 17, 2009. 2:46 PMkemiim.team says:
I want to get into making my own furnishings out of cardboard. This simple, straight forward project will help me launch my burgeoning, enterprising spirit. Thank you.
Jun 11, 2009. 11:24 PMGabey_Chow says:
Hey! This is a really great idea! I don't need a table right now, but when i do, ill do this. =]
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
19
Author:Thursday
I make stuff.
