3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Super Simple Electric Scooter!!
Yes, today we build a friction drive electric scooter that is powered by an 18 volt cordless drill!!
Personal Story: My parents wouldn't let me buy my own electric scooter, so I built one out of stuff we had around the house.
P.S. Keep Dad happy.  Buy your own cheapo cordless drill at Harbor Freight and don't use his!!
Okay, onto the parts list.
> A cordless drill (the bigger the better)
>A simple push scooter
>A piece of stick-on velcro (you will use the scratchy side only. If you can get it use rubber tape.)
>A rectangular piece of wood or plastic (this will support the drill)
>A whole lot of zipties
>A bicycle hand brake and cable (for the throttle)
Here is a link to a video of the scooter in action.
http://www.youtube.com/watch?v=XGU0sXQlGlY&context=C3c53192ADOEgsToPDskJShJx5qy0SGTljaewFJPcT
Step 1Remove The Brake Pedal
Step 1: Removing the only safety system on a razor scooter, the brake!!
My scooter had a small pin on the brake assembly that I hammered out with a small bolt and a hammer.
Your scooter may have a bolt and nut or something like that and it shouldn't be that hard to remove.
Before posting this, I tried to make the scooter with the brake pedal still on. It presented many challenges, so I removed the stubborn thing. Removing it made everything easier.
After you have done this you can move onto the next step.
19 comments
Dec 29, 2011. 4:11 AMOwlgirl says:
My friend has one made by Razor- there expensive so this would be awesome! How fast does it go?? GREAT JOB!
Mar 23, 2012. 3:22 PMentirelyworthless says:
Dude, nice job! Making your own electric scooter at this age, thats pretty cool.
Feb 18, 2012. 5:35 AMOwlgirl says:
Thanks! I really want one!
Dec 19, 2011. 9:57 AMpietzeekoe says:
I think rubber would be a better alternative for the velcro because the hooks pick up every bit of lint they come across and i think rubber would have better traction anyway.
Dec 17, 2011. 4:54 PMmachoturtle says:
Awesome I'm gonna have to try this! Dude go homeschooling, i homeschool too.
Dec 19, 2011. 3:54 AMSharky44401 says:
im doing homeschool aswell
Jan 12, 2012. 9:59 PMpie popper says:
Homeschoolin partaay!! haha
Anyway... nice idea. It looks like it would be kinda hard to ride with the cord and zipties in the way though, what if you threaded those through the tube along the bottom? Your scooter has plugs in it, see in step one where you took out the break...
Good job though :)
Jan 6, 2012. 4:17 PMjavajunkie1976 says:
This is SO annoying, I just thought of this exact same thing two days ago and you beat me to it!!
Dec 20, 2011. 7:00 AMWelsh is best says:
good idea, could look better though.
Dec 17, 2011. 3:41 AMDream Dragon says:
That's a really nice little mod, thanks for sharing it with the world.
It's worth pointing out that you should check your local laws regarding such things. The rules vary and can be a minefield, so take some time to make sure you aren't going to land up with a fine or jail time before you start. I remember doing something similar when I was much younger and getting into difficulties for driving a "motorised vehicle" without appropriate license and insurance. Talking politely to the police and at least knowing the limitations of the machine meant that I "got away with it" but it could be a non trivial concern.
With that in mind, removing the Brakes and not providing an alternative braking system might not be a good idea. If you hack the trigger switch you should be able to move it right up to the handlebars without resorting to break cable and if you do THAT then a relatively simple mod will give you braking effect from the "EMF" of the motor, you might even be able to get some regenerative effect.
Extending the run time with a second battery is a good idea and if you DO that make sure it's another of the same type.
Finally, if you are hacking the battery, then it would make sense to hack the drill too, a lot of the case is empty due to the way the drill is used as a HAND tool, but is not needed for this application. See if you can make it more compact and try to improve the trigger switch/brake cable situation.
Your project is cool, thanks for sharing it, and keep having fun.
Dec 16, 2011. 8:43 PMdoby162 says:
Wow, that actually goes at a decent speed! If you battery lasted long enough you could use that for short distance transport :o) Awesome instructable!
Dec 16, 2011. 9:16 PMtmfitzhugh says:
For additional ride time you could wire two of those batteries together, + to + and - to -, this will keep the voltage at 18v while having a larger reservoir of energy. If you hook it up + to - you will have the same run time but 36 volts and probably burn up the motor, so dont do that lol. Pretty sweet idea and nice job on the instructable! Perhaps you have an engineering career in your future? Keep up the good work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
8
Author:ride on toy dude
I homeschool and build things while i wait for my friends to get back from school. My dad acts and freelances while my mom teaches homeschool to me and my 5 siblings. I fly whenever I can.
