Snoots are used in theatre alot (also called top hats) and are used to prevent light spill and ensure that the only light seen is that reflected off the target, not that from the lamp itself.
Snoots are very useful in the bedroom to allow one to read while not disturbing the other occupants with "light pollution".
Remove these ads by
Signing UpStep 1: Measure twice cut once.
-Knife
-Cardboard (black and thick, flame retardant) DO NOT USE NORMAL CARDBOARD!!!
Alternatively black foil could be used which is obtainable from theatrical shops.....
-PVC tape (Flame retardant)
--Cheap halogen bedside lamp that spills way to much light
Measure the outside of the lamps head (pic 2) and ensure card is long enough.
A piece of A4 should be sufficient for most lamps.
Also measure any protrusions or knobbly bits
Visit Our Store »
Go Pro Today »
I just have 1 small problem with it...
I do not trust paper anywhere near a lamp for any length of time.
Speaking only for myself, I'm at the computer for hours on end(12 - 15 hours or more even)...There is just no way I would feel safe knowing that there is a piece of cardboard attached to my lamp.
That paper is the ONLY problem I have with it. other than that, I love it.
Some of that high quality material comes as thin as 1/32 of an inch(1-2 mm) to as thick as more than 1 inch/cm. I know this because I use to work for a place that made gaskets for the space shuttle & also made pads or shoes for the brakes on a 747 airliner(as well as smaller apps too).
and much of that material had a temperature rating of like 5000 degrees Fahrenheit & up.
I have seen plastic pipe that come in black....would this not work as well? Or would it too be a fire hazard?
Halogens are notoriously dangerous because they run so much hotter than a regular light bulb.
Halogen lamp + flammable cardboard = instant fire hazard!
