loading
I started this for the Stay Warm Weekly challenge,
This step by step guide will teach you how to make a stove/warming can, which in this case, is a big candle. It's very simple and burns for an easy 45 minutes and it's waterproof!
It's essentially a big candle!
Step 1: Materials and Tools
One of the great thing about this stove is the few materials it needs.
Materials:
General:
A tin can: Doesn't really matter what size, how ever big you think it should be
Candle Wax: You can get this form old candles, or buy a pack of tea lights, or a big tub... tons of places
Cardboard
Small stove: nothing special
Big Stove: toilet paper roll
Tools:
Box cutter
Pot
Actual stove
Hammer
Nail
Step 2: Small Stove Set Up
Soup cans are great for smaller stoves, they are fairly think metal and a good size
You start off by cutting strips of cardboard and neatly packing them in, until most of the space is taken up by the cardboard, shown better in the pictures
I did mine in a circular design, which may have been a bad idea. Although it's neat, it didn't allow air to get to the flame.
If you do this design make sure there's a small hole in the middle, you'll see why later.
It might be better just stacking card board in a block and sticking it in
Step 3: Big Stove Set Up
The big stove can be even easier depending how you go about it. I used a big coffee tin, again a great choice. They're common and sturdy
I used a toilet paper roll, because it's already neatly packed, flammable, and soaks up wax very well. You might be afraid of the roll burning too quickly, but it merely just acts as a wick. Since it soaks the wax up so well, it only burns as fast as the wax does.
Place the roll in the center of the tin and neatly pack cardboard around it, filling in the gap between the tin and roll, I also stuck some in the middle of the roll and around the top. Shown in the pictures.
Step 4: Wax
This part can be a bit dangerous, so careful!
Take your wax and place it in a pot. Set the stove on Medium and slowly melt it.
I used gel wax. We had a lot of it. This particular stuff melts at above water's boiling temp. Although it may no look hot, it's extremely hot. I learned the hard way, and have a burn to prove it :l
Little Stove: Doesn't take nearly as much wax
Big stove: takes a lot of wax, I mixed some gel wax and tea light candle wax
Step 5: Pouring
Sorry the picture is sideways
DON'T HOLD IT WHILE POURING, very bad idea
I set it in the sink just after this picture
The process is the same for both stoves
Try to cover all the fillings (cardboard/toilet paper) pour until you think there's enough wax. No actual measurement. The more wax, the longer burn, but also a chance it may have some trouble burning. I filled the little one about a quarter of the way, a fair bit of wax also stuck to the cardboard as well
The second picture shows you how hot the wax really is, that is the wax boiling off the glue that was in the cardboard
For the big stove: same thing, cover all the fillings, the roll will soak up a bunch. I filled the big one about half way,
Step 6: Little Stove Starter
After the little stove stopped bubbling I stuck a piece of cardboard is the middle, slightly sticking out, then covered it in a very light coating of wax
Step 7: Making Holes
This is for both the big stove and little stove
After they both have dried and cooled take a hammer and nail and put multiple large holes around both the top and bottom and middle. A drill might work better towards the top.
This will allow oxygen into the reaction. Allowing it to actually burn. Having no holes will cause the fire to go out.
Little stove:
Although I had holes in my can, since I put the cardboard in circles, it just blocked the air anyway, it did burn for some time, but once it got below the tin, it went out.
Big Stove:
Since there was so much space in the big tin (seen in pictures) holes at the top aren't as important, but holes near the bottom are
Step 8: Lighting/Using the Stove
Little stove: I lite the center piece of card board and held it sideways for the flame to spread then set it down
Big stove: Just set it on fire everywhere in the fillings
If you want to cook on it, I wouldn't recommend putting something directly on it, it may just go out, I would make a stand and have the stove underneath.
The big stove burned happily until it ran out, which was about 45 minutes, the little stove burned for about 10 mins and went out not enough air :l
Step 9: Conclusion
These little stoves work great for keeping warm and cooking! Even if you get them wet, since they are covered in wax, the paper itself stays dry
Mostly a one time use thing, but they can act as a fire starter and emergency stoves. I know I use them quite a bit :)
<p>good to know</p>
<p>Cool stove!!! But please take it off the glass table my sister sat a hot plate of eggs on one in the summer and it shattered in her lap!!!</p>
<p>very cool i will probably try this</p>
be wary of gel wax. in some case depending on the type of container you are using. it can denonate like fireworks can. safer bet is use regular candle wax.
My Uncle may he Rest in Peace was a boy scout leader for over 35 years he made these when i was a kid i'm in my 50's now he made them by the dozens for camping and hiking trips <br> <br>Great &quot;Ible&quot;
how long does it last?
It really depends on everything. How much wax, what type, how big the sove is, how much air. But I did say in the Instrucable how long the big one lasted ;)
a much safer way to melt candle wax is to boil water, and have another metal container(tin can) with the wax in it. this way might be a little slower, however it is a lot safer because the wax wont get that hot, because it can boil over if it reaches a certain temperature.
I learned from my older sister who learned in the brownies about these. they made them just as you describe and then put a large juice can over them with holes to support a pan.
Heh, That's probably where my mom learned it, I went in scouts so we did things from scratch ;) She described it, and I went from there :l They do come in handy though!
About This Instructable
19,119views
34favorites
License:
Bio: I've always loved taking what ever I could find and making something new out of it. I love clocks, Lego, games, and computers. I ... More »
More by WhiteTech:The Self-Suspending Sculpture The 30 second WiFi extender Super Simple Survival Stove
Add instructable to:
