So many uses? Let’s list a few:
* 3D stereo glasses that will work on any screen that uses passive split polarity for 3D regardless of brand.
(Will not work for electronic switched 3D stereo.)
* 3D stereo glasses that work with any color code of anaglyph (common type of color coded stereo image).
* Preview a scene so you can see how it will look when you later photograph with a filter.
* Magnifying glasses with a whole range of magnifications.
* Sunglasses with any shade of darkness or color you like.
* Exploit the extended sensitivity of human vision to see infra red light.
* Protect your eyes from UV or just about any wavelength of light.
* Have different things happening with each eye.
All this and more from one pair of glasses by simply screwing in your favorite filters in a few seconds. Moreover you can make a pair of these quite cheaply in about an hour if you already have the parts.
OK, OK there is a little catch; to achieve all this you are going to have to get various camera filters to use in your Super Specs. I can guess you are thinking “Oh Oh! This is going to be expensive.” But there is a way to get a whole range of cool camera filters that are very cheap and will still work on your camera too: get them on eBay and try clicking that box so you can search worldwide; what you need are the Chinese suppliers. I have bought polarizers for as little as $3 and you can often get bundles of mixed camera filters for less than $20 all brand new.
Having said that I guess it will be no surprise that I bought everything for this project on eBay. Even though I did the purchasing some months ago, I have done fresh search to get prices for the parts list (including postage). Your mileage will vary depending on patience and luck finding bargains.
To attach the filters to the lenses so that they can be easily unscrewed and changed I glued two lens adapter rings into the glasses frames.
(Please vote for me, I would really like to win the Epilog laser cutter. Thanks)
Remove these ads by
Signing UpStep 1: Step 1, What you will need:
If you plan to screw in heavy filters or lenses (for example fisheye lenses) then you may need a glasses frame strap to keep them on your face.
Parts List:
One pair of “Lady Ga Ga” fashion glasses or other glasses with large circular framed lenses. ($13.20)
Two lens adapter rings to fit the glasses. ($1.82 each)
At least one pair of filters to start. eg. 2 circular polarizers at $6.18 each.
Some metal/plastic adhesive (eg. 5 minute Araldite) (You only need a tiny amount.)
So all up less than $30 or much less if you have filters already for your camera.
Tools:
Miniature (Jeweler’s) screwdrivers
Dish of boiling water
Visit Our Store »
Go Pro Today »
In a moderately dark room most people can see the NIR LEDs around a surveillance camera after the eyes adjust, and even the IR LED on a TV remote in a really dark room. Though you should keep a respectful distance and short exposure when doing these experiments, I have heard there is a risk of eye damage if you are not careful with some NIR sources. Keep in mind your pupil opens up fully in the dark and your eye can be easily damaged in that state.
Usually an optical device will not suffice when the two channels require electrically switched elements in the glasses. So if your 3D TV uses glasses that have some sort of electrical power then it is most unlikely any passive filter will work for you.
The super glasses is a great idea and I think they would be comfortable for a long time with my type of support
learned alot about all that when was making steampunk goggles. http://www.flickr.com/photos/killbox/4475363810/
odd effect of polarized filters CPL or not, is if you try and see your own eyes in a mirror though your glasses the lenses will look totally dark. as the light from behind the lens is filtered then hits the mirror and is filtered coming back.
What type of glue did you use?
http://en.wikipedia.org/wiki/Araldite
Araldite is a 2 part epoxy glue that is OK for plastic and metals among other things. Other strong adhesives would be OK provided they work with plastic and aluminum.
maybe I should speed read less
I think I'd have to go one step further and pair these with a leather flying helmet fitted with earphones. The googles could be altered to accept an elasticated strap.
Very clear instructable too.
"Sunglass Eyeglasses Glasses Sports Band Strap Retainer"
I have one coming so I can use heavier filters and lenses.
