loading
loading
Picture of Super Stilts
Ever had the desire to be really tall? or be able to dunk a basketball? or to see what the world looks like if you were tall? Well for all you short people here's the answer! All you gotta do is build the stilts, practice walking around awhile, painfully fall a few times, whack your head on doorways and light fixtures a couple times, and voila you are tall! It's about time you started rockin' the neighborhood in your very own pair of super stilts.
Step 1: What you'll need
1. Wood
2. Drill
3. Screws
4. Two old belts
5. No Fear of Heights
That's all..............what are you waiting for keep goin!
Step 2: Find the legs
Picture of Find the legs
First thing your gonna need to do is find two 2x4s the same length for the legs. I made mine 2' 2". The higher you go the bigger base your going to need.
Step 3: Cut base plates
Picture of Cut base plates
Now find some good plywood and cut it into a rectangle. Mine is 11" by about 6" but if your making your stilts any taller than 2' you'll need bigger base plates than that.
Step 4: Cut triangles
Picture of Cut triangles
Now cut out four triangles, all the same size, out of a square board. These will be used later on for support.
Step 5: Cut the foot plates
Picture of Cut the foot plates
Now cut out two pieces for your foot to stand on. To get the length, make it as long as your foot is and cut two the same size.
Step 6: Screw the base plate on
Picture of Screw the base plate on
Screw the base plate onto the leg. Make sure the leg is in the center of the base plate and not shifted to one side. Do this to both stilts.
Step 7: Screw the supports on
Picture of Screw the supports on
Now take the triangle supports and screw them onto the sides of the leg to give it extra support.
Step 8: Screw the foot plates on
Picture of Screw the foot plates on
Now center the foot plates on the stilts and screw them in.
Step 9: Cut up the old belts
Picture of Cut up the old belts
Now cut the old belts. Cut them both the same. For the first cut slide down the belt about 3 inches from the buckle and cut. For the second cut slide about three inches down from the last hole and cut.
OTP12 years ago
Great job
woofboy1112 years ago
To restate what was already said, these stilts are extremely dangerous.
I'm a stiltwalker who has experience on drywall, acrobatic, and homemade peg stilts. In every pair of stilts I've used, the calf strap is most important. The straps around your feet do have their purpose, but it is the calf strap that provides stability. Be really careful on these...
depending on what you're doing, I'd even recommend a helmet. this coming from a guy who got an ambulance called on him (and a fairly serious concussion) for smashing his face into the ground while running around (without a helmet) on jumping stilts.
but, safety issues aside, they look like nice stilts.
Knee pads can't hurt either to protect from forward falls...
chemkid422 years ago
what are the dimensions on the square wood you used?
sfstilter2 years ago
I am professional stilter of 10 years and I think your stilts are super cool however they are VERY unsafe. Stilts are an extension of your leg and the way you have it set up they are an extension of your foot which will cause an ankle break. A good stilt needs to include a support up the outside of the leg to the knee and then either a shin plate or calf plate for support. If you would like help designing a comfortable, safe, and light weight stilt please message me andI will gladly help you. I have made hundreds of stilts in various shapes and sizes.
Congrats on a pair of stilts and an even bigger congrats to getting up on them. In the stilting scene we have a saying "let's get high and have fun!"
Kinnishian2 years ago
To reiterate the point everyone kind of made, is that there's basically a leverage force going against your ankle now. So you want to bypass your ankle, since your shin is a lot stronger than your ankle joint.
If your foot is normally some 4 inches from your ankle, now you have a force being applied some 30 inches from the same point = 7.5 times higher force.
But, otherwise, this is awesome! Thanks for the instructable
machoturtle (author) 2 years ago
These are SO cool! I love your front page picture!
machoturtle (author)  machoturtle2 years ago
That was my sister. She thought she was on her account. :)
lol
cortchops2 years ago
perfect for slenderman
poofrabbit2 years ago
OOOH this could be so cool in use with a costume! Very well done!
ilpug2 years ago
There is a reason why most stilts have small tips, and extend up the side of your leg- it lets you fall over easier and distributes all the stress along your leg. Your design has neither of those features. This is fun, and I am not saying that you shouldn't have fun doing it, just letting you know that there are safer ways to do this.
lemonie2 years ago
These look "lethal"; you haven't got enough support to stop you wobbling and prevent your ankles from failing.
Don't try these.
L
machoturtle (author)  lemonie2 years ago
just edited and changed it to have some more support. Thanks for the tip
I'm impressed, but they still say "broken ankles" to me... : )
L
ya i know what you mean lol i fell today on them and it hurt my ankles not bad though...i got right back up and kept goin
Good for you to get back up, but check your health insurance policy carefully...
L
Kiteman2 years ago
Oh, come on!
Let's see them in use!
machoturtle (author)  Kiteman2 years ago
there got a picture up for you!
Cool.
(I think what Lemonie is talking about is ankle support, not actual stability - most stilts that strap to your foot also strap to your calf, to stop a stumble snapping both your ankles. The size of the "foot" of a pair of stilts is often unimportant - I've used stilts with the bottom end about the size of a penny.)
rimar20002 years ago
Change the last photo, it lacks a pair of straps.
And add a video, please.
machoturtle (author)  rimar20002 years ago
changed it!
