Introduction: Super Strong K'nex Broadsword
Picture of Super Strong K'nex Broadsword
This is the k'nex sword I designed a year or so ago. I've upgraded the hilt since then. I recommend not building this if you don't think that you'll be able to deconstruct it, as that is the main problem. Because of how strong it is, the full picture is only 2/3 of it. I have on side serrated mainly to save on the yellow connecters, but if you don't want a serrated edge just replace all the yellow connectors with the pegs with ones without one.
Step 1: Total Pieces
green rods: 223
white rods: 122
red connectors: 5
green connectors: 6
yellow connectors: 111
white connectors: 28
total: 495
15 of the yellow connectors can be replaced by the ones with the peg on the back if you want a serrated edge.
Step 2: Hilt
Picture of Hilt
I will not put any of the white or green rods on the outer layers until the end so that mistakes are easier to fix.
Step 3: Crossguard
Picture of Crossguard
Step 4: Blade
Picture of Blade
This is the largest step and is rather hard on the fingers. If you don't want the serrated edge, use normal yellow connectors instead of the ones with the pegs on the back.
Step 5: Connecting It All
Picture of Connecting It All
Now to add them all together. You will have to temporarily remove a few pieces to connect everything, which is why I didn't put the green or white connecters on the outer layer.
Step 6: Adding the Rest of the Pieces
Picture of Adding the Rest of the Pieces
For the rest of them, just put them where the gaps are. I would of shown how, but I had to make sure I could disassemble this after.
tomatoskins (author)2015-05-11
That's a great looking sword! Thanks for sharing and welcome to the community!
About This Instructable
273views
0favorites
License:
More by andrew.cobill:Super Strong K'nex Broadsword
Add instructable to:
