A wallet made of five Tyvek credit card sleeves, often used to package gift cards. Tyvek is a durable paper compound used for event bracelets and packaging envelopes. Glued together, these five Tyvek card cases make a durable, simple, small wallet. You can simply collect these as you receive gift cars. I actually bought them off ebay for $3 (for all five). This design easily holds eight credit cards and five bills (my current load).
Use your old wallet as a template and traced around the thumb slider with a pen on the Tyvek. These two sleeves will be the outer card holders. Once you outline the thumb slider, cut the hole out with a razor blade. Make sure to put an old or unused card in the sleeve so the blade doesn't cut both sides. Additionally, you should cut a quarter inch slice off the top of the sleeve (third picture) to shorten the outer sleeves relative to the rest of the wallet.
origima style into a functioning wallett.
i bought it at a store in the village but had to make some mods to iy to make it usable.
The first problem was the materiasl was way too slippery. i would take the walett out of my pocket and it would shoot out of my hand if i had a firm grip on it.. losse grip and it would just slide out. i was worried i was going to lose my wallett so i had to use rubber bands on it for a while got the added friction in ,my pocket.
i found some clear spray acriylic that is osed for traction on stairs, etc.
i gave the walleett a couple coats and every month or so i give another coat.
the spray acrylic solved the slip problem.
I had to glue a couple areas, as the folds were coming undone when opening it, no big deal.
i have to remember to pick up a subway map and see if i can replicate the folds or try a different design.
i get compliments everyday at the cashiers when i pull out my wallet.
people always ask where i got it .
The other good thing about the subway map design, is the grab and run thieves are less likely to target you when paying for a item at a outside vendor. They think your holding a free subway map.
THERE FREE!!!!!!!!!!!!!!!!!!! hooray!!! that means if you mess up, it really doesnt matter!
