Design problems
- Too short- must bend over to use. Strains the back and reduces use of body weight to drive the plunger.
- Wrist extension (dorsiflexion)- weak wrist position. Damaging/tiring the wrist, which must transfer power from the body/arms to plunger.
- Handle surface area too small- resulting in painful contact pressure.
I found a cast-off aluminum cane, perfect to upcycle and improve my toilet plunger. I tapered the wooden handle and flared the aluminum tube creating a strong, overlapping connection. Secured with a few wood screws and finished off, the final plunger is much easier to use.
Remove these ads by
Signing UpStep 1Materials and Tools
- Aluminum walking cane
- Toilet plunger
- Waterproof paint
- Wood screws (5) #6 size, 1/2 " length
My tool list is not essential, but includes what I found useful:
- Wax pencil
- Center punch
- Hammer
- Drill
- 3/8" drill bit
- 1/8" drill bit
- Hacksaw
- Mitre box
- F-clamp
- Dremel
- Dremel Wood Shaping Bit
- Sand Paper 60 grit
- 5/64" drill bit
- Screwdriver
- Paint Brush
- Dremel silicone carbide grinding bit
Something like this perhaps- my kayaking bilge pump attached to the plunger head. Add some tubing on the out spout and your idea would work.
The kayak pump is not really heavy duty, but it does feature one-way flow and handles a large-bore of water... I'll put this one on my to-do/experiment list and get back to you!
** Your results may vary. This comment was included for educational purposes only. Use at your own risk!
RE ehricweiss's ?: I pull more than push (just as n0ukf suggests), greatly reducing splash. Better typically to loosen a plug, than trying to push further down system. Either way, the longer handle keeps me a safe distance from burps. Having more hand control allows for more finesse also.
I suspect I'm the only person in the world that is concerned about toilet plunger finesse...
Think again
Hopefully you will be smarter than I was, LOL
Take care
Despite this, with most toilets you can get more effective action by slowly pressing down then quickly pulling. The suction will pull stuff loose while not squirting out the sides. Or after that initial slower push you can quickly oscillate it up and down to work the clog loose.
I still get a little burp of air after finishing, but I just deflect this with the plunger head, muffling the splash.
Crisis is a perfect word to describe the scenario. Great hack on an everyday tool!
