Step 3: Attaching the Towel
At this point, you should have four loose cord ends hanging in front of you. We'll be tying each loose end to a corner of the towel using a sheet bend knot. If you don't know how to tie a sheet bend, go to the final step for a brief tutorial, then come back here. It's OK, I'll wait for you.
Designate an end of the towel as "top". Designate one paracord as "left" and the other as "right". Take the "left" loose paracord end and sheet bend it to the corner of the towel on the top end on the left side. Repeat with the "right" cord on the right top towel corner. Be sure to tighten the sheet bends carefully.
Hoist the towel up so that the towel is hanging vertically at approximately shoulder-height for the person who will be using the chair. Lift a bottom corner of the towel to approximately waist-height and sheet bend the corner to the loose end of the paracord on the appropriate side. Repeat for the other corner. Tighten both sheet bends carefully. There will be some extra cord hanging off of the bottom end of the towel. Bundle and tie the excess cord so that it doesn't drag the ground.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
