Step 7Adding a rubber tyre to a small (wooden) wheel
You can make a groove in the wheel and mount a round rubber joint with a diameter slightly smaller than the wheel. This works best with wooden wheels. You can find rubber joints in many sizes in the better stocked Do-it-yourself store. The groove can be made with a power drill as an improvised lathe, as long as you can firmly mount the power dril and have a stable support for the "chisel". You do not need a real chisel. I use a large file. be carefull though!
The second alternative is cutting some rings from using bicycle inner tubing and mounting them on the wheel. You can use a number of layers to achieve the desired diameter. The picture shows the result.
Add Comment
