Super Long Ranged Sniper
28,782
69
140
Posted
Introduction: Super Long Ranged Sniper
Keep out the Pesky rodents from eating your Veges by shooting darts through them ! Or put a marshmellow in it and shoot your little brother! Do not shoot darts at anyone or anything you dont attend on killing or serverly hurting!! '
DISCLAIMER: MAKE NO MISTAKE, THIS IS A WEAPON. DO NOT SHOOT AT ANYTHING FRAGIAL OR ANYONE. IF ANY PROBLEM OR DESTRUCTION IS CAUSED BY THIS, I CLAIM NO RESPONSIBILITY.''
Step 1: LETS GET STARTED !
What you need:'
4ft. of 1/2in. PVC( you will have extras)
2 1/2in. Tees
1 1/2in. Flat Cap
1 1/2in. round cap
1 1/2in. Ball Valve
1 1/2in. Elbows
1 Maxi lock string holder that can fit over male 1/2in. PVC (optional)
Scope or whatever you what to use as a sight! (optional)
2L Coke Bottle
PVC Cement
Drill and bit
Little Marshmellows (optional)
PVC Cutter
Ball Pump and Adapter used to inflate air mattresses (make sure it fits in a ball pump) '
Cut the PVC into these measurements!'
A= 23in.
B= 2.5in.
C= 2.5in.
D= 5.5in.
E= 3in.
F= 4in.
G= 2.5in.'
Step 2: Drilling the Hole!
TAKE the drill and drill a hole in the flat cap! Make the hole big enough but small enough to put the adapter in tightly !
Put glue on the inside of the Flat cap and let it dry !
Make sure it doesn't move in side..... then put glue on the outside of the cap !
Make sure it has no holes left!! '
Step 3: Put the Scope on !
Time to put the scope on ! This is completely optional! I use a Daisy Air Rifle Scope! They are about $8 at Wal-Mart.... !
Well its time to put it on to put it on take two scrap PVC peices that are the same size ! glue the Scraps to the barrel and let it dry ! After it drys glue the scope to the scraps !! And let it Dry!!
IF your having trouble understanding what im saying, look at the PICS!'
Step 4: Make the Tank!
NOW lets put the tank together!
First lets start with the BALL VALVE ...... its connected to Peice (B) !
Peice (B) is connected to the (Tee)!
Lets go to the (Tee)'s bottom open slot where (C) goes in ..... and the (flat cap) with the adapter
connected in it!!
There should be one more slot open where Peice (D) goes!
The elbow connects to Peice (D)! IN the othe open slot put peice (E) in there!
YOU should have another (TEE) left and connect it to Peice (E) on the bottom peice that doesnt have have another open slots like that!
Put Peice (F) on the left slot and put the cap on it !
Heres the last step..... put Peice (G) in the last hole on the (TEE) ...... and put the COKE BOTTLE over peice (G) then Glue it!!
THERE YOU HAVE IT !! THE TANK IS DONE!!!!'
Step 5: PUT the Rest on !
Now you should have the Ball Valve and the Barrel left! !
Put the Ball Valve and Connect it to the barrel! (DO not GLUE this is the single most expensive piece you HAVE TO BUYand once you glue it on tightly you cant get it off! )
Now you have the Valve and the Barrel Connected!
Now connect the Barrel and valve to the tank ! i would recemend you not glue the tank to the Ball Valve! i would just use strong tape to hold it in place!!
Step 6: ADD FINISHING TOUCHES!
NOW its time to add Kool Things to it like The bipod and suppressor!!
FIrst lets talk bout the BIPOD!
NOw Find To long Peices OF PVC and cut them the same size! (if you dont have extra PVC find something else or you dont have tho make a bipod!
Now glue the to legs wereever you want them !
there you have it a bipod!'
Step 7: LETS ADD THE SUPPRESSOR!
NO ITS TIME TO ADD THE SUPPRESSOR!
i used a MAXI-LOCK sewing string holder!
you can use anything that looks kool and fits!!!
Now to put it on slide the end on till it fits snug and then glue it and there you have it you super air rifle!!
Step 8: NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
NOW YOUR DONE!!
ok i gues you get it lol! shoot whatever ammunition you want!!! TELL ME HOW YOU LIKED THIS INTRUCTABLE !!!! IF YOU HAVE ANY QUESTIONS ASK ME THEM ! IF YOU THINK THERE IS SOMETHING I MISSED TELL ME AND I WILL TRY TO FIX IT!!'
!!!!!!!!!!!!!!!!!!!!!!!!!ENJOY!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  • Minecraft Challenge 2018
  • Sew Warm Contest 2018
142 Comments
how long dose the barle have to be
cant you just put a cap on the end instead of a coke bottle?
no becouse the bottle holds the pressurized air.
But you could also make your own air container from a bigger pvc pipe.
Nice one! I have a similar design and principles with your design, the only difference is I do not use CO2 or air pressure to fire the gun. Instead the tank which I customized was made of 1 1/4" x 12" PVC attached with a stronger plastic bottle neck including the cap on both ends and attached to gun. It uses a denatured alcohol as a CO2 charger by means of igniting it inside the tank. Two ends of wire is then drilled to the tank and was attached to an electric igniter of a conventional lighter as the trigger, just adding a strip of plastic to look like a real gun trigger for better firing. The principle is explosive and more powerful and uses a marble as the bullet. Firing the riffle without the marble inside the barrel will create an explosion as strong as the firing of a .38 caliper revolver. A load of marble inside when fired can penetrate a 2 pcs. of 1/4" thick plywood. I had tried it shooting a mad dog on the loose in the neighborhood and the marble managed to penetrate to the skull of the dog that killed it. I am still on the process of making the design to be instructible for all to compare and try.
this is cool but you've got to be careful because one PVC is not all that string after a bunch of high pressure high heat explosions and is liable to shatter (some people use copper pipe instead a lot stronger in every way and doesn't shatter and looks a bit better aswell) and two this is legally considered a firearm in most countries as it uses explosions (cant remember the technical word) and also the fact it killed a dog, it would almost definitely kill a human...so don't flash it about when the cops are around.
Make a video!!!!!!!!!!!!!!!! :D
how is part G connected to the bottle, I assume you used PVC cement
this is awesome                                      do u think it would be suitable for paintball?  and can you make one of those pvc air tanks?
he our names are simalar
You haven't maximized air flow.... and a coke bottle not to safe, a little scratch and it will go bang! lol. you went for to much effort for a little outcome. NICE JOB THOUGH
