This instructable addresses personal security. Yes, there are $20 PIR (Passive Infra-Red) motion detector alarms out there you can get at Walmart or Radioshack, but why not make one that can
1) Communicate verbally and...
2) Be loud enough so that IF it happens to go off, EVERYONE around will know, and (hopefully) call for help.
We all know that many of those battery-powered, $20 alarms that come with double-sided tape that you can mount aren't very loud, and if you DO happen to have one that is REALLY loud, it is your professional, built-in multi $K wired security system. Well, this one uses a microcontroller, which means you can wire the sound output to an amplifier, be it homebrew (DIY) or one from the store.
Here's a video of it in action:
Step 1: Find the stuff
Here's all that's used:
  • Parallax BASIC Stamp IIe microcontroller
  • Parallax 'Board of Education' carrier board
  • RGB LED (I used THIS ONE)
  • 220 ohm resistor
  • Some solid core wire
  • Parallax PIR sensor (you can buy it online, or get it @ radioshack)
  • Emic TTS module (from Parallax's online store; I was going to use this for another project, but that one was too big and expensive, and I never got around to it)
  • Male header pins (I used THESE)
  • Power supply
  • Sparkfun connector wires (or any other wires that have crimped, plastic-housed, female connectors on both ends). I used THESE.
demolitionNerd says: Feb 1, 2009. 6:42 PM
Do you think you could set up a way to add more than one PIR to the circuit or would that require a different circuit all together.
RPisces (author) in reply to demolitionNerdFeb 2, 2009. 5:36 PM
Ohh yes of course; this uses a microcontroller with 15 I/O pins! You could probably have 10 more if you wanted.
kd4nsv says: Aug 17, 2008. 9:57 AM
Nice job. I built something similar with the same type sensor. Mine is connected to my computer that sends a message to my cell phone.
thaiger17 in reply to kd4nsvDec 23, 2008. 9:56 PM
Hey I just had someone break in to my car bashed my window in. How do you make that device you just mentioned. I want to be able to be in control. So when someone breaks in again it will beep my phone and I will be out to my car faster than lighting. How do I make that device!?!
ReCreate in reply to thaiger17Dec 29, 2008. 4:13 PM
id hook up an electric fence generator to the car door and frame so when someone touches it ZAAPP and that can be de-activated with the key chain remote
kd4nsv in reply to thaiger17Dec 23, 2008. 10:21 PM
I hooked the output of the sensor to the button on a remote. I have a ir receiver hooked to the serial port on my PC. I use winlirc and eventghost. The computer is on all the time to record TV programs. I arm and disarm it with a separate remote.
Thelonelysandwitch says: Oct 17, 2008. 12:50 PM
Just get one of those energiser alarm/flashlight things and tie it to a tripwire.
pyro man in reply to ThelonelysandwitchOct 27, 2008. 6:32 PM
dude ur like everywhere
Thelonelysandwitch in reply to pyro manOct 28, 2008. 12:21 PM
im everywhere but nowhere. if I am where you are then im hidden or somewhere else.
pyro man in reply to ThelonelysandwitchOct 28, 2008. 2:13 PM
iv also seen youas capn tac and one other thing but i forogt where it was
Thelonelysandwitch in reply to pyro manOct 28, 2008. 3:34 PM
when was I capn tac
Gjdj3 says: Jul 22, 2008. 10:20 AM
This is cool. Nice job! I've been looking for a good design like this. 5 stars.
joejoerowley says: Jun 13, 2008. 11:55 AM
Cool! Great Instructable! Thanks Joe
RPisces (author) in reply to joejoerowleyJun 25, 2008. 6:55 PM
Thanks! Doesn't look like other people have seen it yet...lol
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
