3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Super-slim, cool-lookin, EMI-shielding wallet
Ever get tired of carrying around a huge honkin' leather wallet?
Want to impress your hipster friends with your wacky style?
Worried about your credit cards getting erased by all those stray electromagnetic fields you've been hearing about?
Then this is the wallet for you.
Step 1Cut pieces
cut pieces
grab the anti-static bag that your CD-ROM burner came in, and cut it into tiny pieces.
9 pieces 2.3" by 4.5"
1 piece 4.5" by 9"
17 comments
May 3, 2008. 9:01 PMtabornakz says:
fortunately, I amaze with ur idea..thx for the idea...hmmmm...its smell money. better to make business with it...
Apr 11, 2008. 5:23 PMringleader369 says:
...what a spiffy idea!!...my dad has a bunch of that lying around......hmmmm might make wallet....THANKS........giving you a good rating
Jul 30, 2007. 10:32 PMian_fleming007 says:
Tweeks is right...it must be made of wire mesh. I found this site http://www.rfidblockr.comThere wallets, passorts covers are made of copper mesh that creates a true faraday cage. DIFRwear only uses tinfoil in their products but it still works but http://www.rfidblockr.com I think will last later because it is copper wire mesh.
Mar 22, 2007. 2:13 AMstranoster says:
maybe adding a clip from a 9v battery halved and on a strip like on the wraparoundish things to shut it? I dunno but Great Instructable! My wallet was getting lame!
Jan 19, 2007. 10:00 PMplace name here- says:
Nice cool instructable dident quite understand it all but cool.
Dec 27, 2006. 7:29 AMJonC says:
i know this is old, but still point 1 : this material is indeed electrically conductive to prevent static, static often charges to many thousands of volts this material is designed to prevent that. Point 2 : A EMI sheilding pouch for mobile phones?! Mobile phones for by EM radiation, so wrapping your phone in shielding would block it from getting any signal too...
Mar 27, 2006. 3:51 PMmrtools says:
are there other places i can get this meterial besides as a packing material
Aug 5, 2006. 4:33 AMjoncas says:
You can try the Shieldon fabrics: www.shieldon.com
Aug 5, 2006. 4:28 AMjoncas says:
Try theas shielding fabrics: www.shieldon.com. It might work
Apr 15, 2006. 5:52 PMpmetro says:
check out these sites refered by wservernews.com newsletter
https://shop.foebud.org/product_info.php/cPath/30/products_id/58
http://www.difrwear.com/products.shtml
http://www.wservernews.com/EQE61C/060417-RFID_Zapper
how about clothing and accessories that are shielded for persons concerned about EMI, RFI shielding and RFID crackers, etc. ??? marketable ???
sample ad "only wear clothing and accessories that carry the ------- logo to protect yourslf from EMI RFI emmisions.
cell phones with shielded enclosures to protect against blue tooth sniffers and RFID crackers....
Mar 19, 2006. 6:30 PMpmetro says:
has any one tried making a shielded pouch for cell phones ?
Feb 12, 2006. 11:11 PMThe Dragon Master says:
If you are looking for an RFID blocking wallet, try http://www.i-hacked.com/content/view/208/48/. It's an article about how to make an RFID blocking wallet using aluminum foil and duct tape. Haven't tried it myself though. I don't use any RFID cards so I would have no way to check. Though I like this idea. I am making a tri-fold version of this wallet. I like that the material will be much thinner than the leather wallet I currently use.
Feb 11, 2006. 4:46 PMBob N says:
To stop a magnetic field, you can use Mu Metal foil.
http://www.lessemf.com/mag-shld.html
Watch out for the sharp edges of the foil if you play with this stuff.
Feb 11, 2006. 2:11 PMtweeks says:
That stuff is for ESD (electro static discharge) protection. Not EMI or RFI protection. If you want to stop RFID waves, you will need a wire mesh with a mesh size 1/4 (or smaller) than the frequency wave length. In your case.. regular window screen should be fine.. but is not flexible. Google for "Faraday Cage" to get an understanding behind the tech. This is.. if you you want to build something more than just a shiny wallet. ;) Tweeks
Feb 10, 2006. 5:40 PMvaiodon says:
That material isn't EMI shielding, it's simply electrically conductive so as static charge doesn't build up on electronic devices that aren't in situ, connected to power and, consequently, have a path to earth/ground.
Feb 10, 2006. 4:24 PMEMIExpert says:
Looks cool... don't expect it to actually work, though. I tested the material using a closed bag with my RFID security access card and it made zero impact on the distance the card was detected from the reader. The material is static dissipative, but not EMI blocking in the frequency range used by RFID cards. Magnetic fields are not affected by this material either, so it cannot protect the mag stripes on your credit cards, etc. Highly conductive metal foil (iron/steel for magnetic shielding) is needed for EMI shielding.
Feb 10, 2006. 4:01 PMehmbee says:
Cool idea-I recently experimented with this material... I found the thin heat sealing wire on one of those home vacuum sealers will bond this stuff together perfectly! May save you on some stitches, or to make sealed bags for larger items you may want to protect from EMI. ehmbee
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
10
Author:geo
