Step 4Install the vertical support bar
We located the center of the bar and moved the tee to that area.
Then I placed the vertical support bar, which consisted of a 5ft. bar with a flange on the bottom, and a coupling connected to a 5" nipple at the top.
Slightly flexing the horizontal bar up, the support bar screws into the tee from the bottom.
I leveled the vertical bar in 2 directions, and marked the floor where I was going to drill 2 holes into the concrete.
Then I drilled through the hole in the tee into the horizontal bar.
I drilled the holes into the floor using a 1/4" masonry bit, and then I tapped 2 plastic plugs into the holes.
Then I screwed the vertical support bar's flange to the floor.
The next step is to put a screw through the hole in the tee, and into the pipe.
This secures the tee to the pipe to keep it from sliding around.
Add Comment
