Often times I am photographing a late wedding reception and running low on juice or will need to recharge gear for the next day's shoot while at still at a late shoot. More frequently I find only one outlet available near our table and need to charge several items at once.
This is the easiest solution I have found using the cables included without buying special chargers that handle multiple batteries at once.
PARTS
+ 2 or more Camera Battery chargers
(1 usually comes with the camera)
+ 2 AC leads for the chargers
+ 1 Inline AC ungrounded plug - hardware store
+ Heat shrink tubing - 1/4" for AC leads, 3/4" to cover split connection
(black electrical tape works as well
but a nice piece of heat shrink
won't unravel or leave goo
while keeping the look of
well built, professional gear.)
+ Epoxy / Epoxy Putty / Hot glue - encase split junction
(come on, doesn't every project on here use one of these 3 adhesives?)
TOOLS
Wire cutters, strippers
Soldering iron, solder
TIME
30 minutes or so? Not too tricky or difficult once you have the parts together.
** All the external hard drives I use have the same kind of figure-8 AC leads to the power bricks, and this Instructable can be applied to powering multiple drives or any other peripherals using same ends. **
Remove these ads by
Signing UpStep 1Gather Gear
We add an AC extension inline with the figure-8 ends!
(cut and splice hot wire 2 inches longer than the neutral on the supply side, and inversely on the load side, so the 2 joints aren't side by side)
Wonderful ible -- I've done a few custom wires like this for computer equipment before where an extra power bar would just be overkill :) 5*
I've got a 3-ended cable like this under the desk to power 3 external hard drive power supplies with less cable clutter too, works great! Over the last year the parallel blade outlet on this cable has been used more with a MacBook Pro 85W charger instead of the AA charger pictured as needs have changed. That was the best addition to this custom cable for location work.
I have shot the Nikon D70/ D70s, D200 and D300, and the body battery chargers pictured herein will charge body batteries for all of these bodies. (The EN-EL3a battery will work in all these bodies.) This project can be applied to chargers / splitters for just about any camera brand.
What the cameras cost is dependent on where, when and from whom you purchased them. This is a post about an AC adapter cable and I'm not up for price busting or brand comparing, just battery charging. There are plenty of camera clubs and forums for waving around what you use and what you spent. I prefer to just show the photos made with whatever camera it is I'm holding.
My photography is found at http://ebphotography.com if you're curious what the above cameras can help make once they have fresh batteries charged and ready. All photos I've posted there were made by having battery chargers working to make sure I plenty of juice for the great shots when they were taken.
