iImage Information
Scare the crap out of your friends with this new "supercharged" 9 volt battery!! WARNING: If you have a pace maker or are dependent on any other electronic device for life support do not touch this battery!!!! also i am not responsible for ANYTHING stupid you do with this including but not limited to loss of life or loss of property due to 1 hell of a jolt!
ALSO make sure the capacitor is discharged before you go messing with it
Step 1Parts!!!!
2 9volt batteries!
1 soldering iron w/ soldier
1 hot glue gun w/ hot glue
1 16v 3300uF capacitor
common sense
Capacitors only explode impressively with voltages well above their rated maximum from my experience though I've never seen anything other than smoke, a big bang and a case flying around. Automotive bulbs though are very impressive with 230V AC though they cause glass to be propelled in all directions.
Thanks.
A 3300-uF capacitor charged to 9 volts will store, at best: (0.5)(3300 uF)(9 V)^2 = 0.13 Joules of usable energy.
A typical 9-volt battery provides 10 to 20 thousand Joules of electrical energy over the course of its useful life. In other words, the original battery could have held over 100,000 times as much energy as the "supercharged" version.
To give an idea of scale, running a small LED for 10 seconds might use up something on the order of 0.25 Joules, over twice what that capacitor can hold.
For all intents and purposes, this "supercharged" creation is several orders of magnitude less dangerous -- and less useful -- than the original ordinary battery.
Use your heads, people.
You can have a 100,000v van de graaf spark and not die from it.
Its the current that kills you. If there isn't enough current flowing voltage won;t do anything.
This definitely won't kill you, but it'd give a nasty jolt....
