On this step I've included some samples of the instrument in use. All three mp3s are the same snippet, recorded three different ways:
"tub_bass_mic" is an acoustic recording using a regular old microphone, as evidenced by the background noise and sounds of people walking around in my studio
"tub_bass_contact_mic" uses the contact microphone - squeaky clean and provides very different tone than a normal acoustic microphone
"tub_bass_mix_with_eq_and_reverb" - a mix of both mics with some EQ and reverb, this is probably how I would use it on a record
Sweet!
Remove these ads by
Signing UpStep 1Overview
Our bass makes use of plastic-coated galvanized steel cable (a.k.a. plastic-coated aircraft cable) for the string - this will be nearly impossible to break and provides far superior tone and playability to parachute/nylon cable. The plastic coating allows you to play the string with bare hands.
Our neck is unattached and pivots on the rim of the tub. Notes are thus created by flexing the neck to change the amount of tension on the string. This makes for a more intuitive playing style than an instrument with a fixed neck and fret board, but it will take some practice for your muscles to learn how to hit and hold specific notes. A used-up wire spool acts as a slide-able capo, allowing us to play in different pitch ranges/keys.
Our instrument also adds an optional pickup for amplification in the form of a contact microphone. I made mine from scratch using the recipe from Nicolas Collins' excellent Handmade Electronic Music (essential reading for instrument makers/hackers), but readymade contact mics are also available on the cheap.
This is the same tub bass that is used by The Asker Brothers to achieve their signature thwonk-a-donk sound. Let's begin!
i was able to find a good washtub at my local hardware store, it looks kind of like this.
good luck!
jesse
