iImage Information
This tutorial is how to make a survival/hunting knife using a few basic materials. It cost me nothing since I already had an old sawblade laying around.
SUPPLIES...
Circular Saw Blade
Dremel Tool with attachments
Safety Glasses
Other Optional Supplies:
Fine Sandpaper
Steel Wool
Steel File/s
Gloves
Wood (for handle)
Step 1Drawing the Pattern
iImage Information
When drawing the pattern, keep in mind that you should save room for a handle. Besides that the possibilities are almost limitless. I used a black sharpie marker and drew directly on the blade.
only the carbide teeth(on the authors bade) are hard.
This is a very good material, if you're just learning about knives.
It'll force you to sharpen a LOT more frequently.
and practice makes better.
that's why cubscout and boyscout knives are always going dull.
It's on purpose ;-)
IF one of your blade blank lines is straight, I'd suggest going for a score and snap method. Score the line a few MM deep with the dremel, then clamp in a vice just below the score, and bend. You SHOULD get a nice, satisfying 'snap'. If it bends instead, just bend back and forth a few times, like you would a pop tab, on a can of soda. It'll go :-)
Also, being mild steel, a hacksaw with a nice sharp new blade, will cut nearly as quickly as a dremel, with a mini cutoff blade. more armwork, but less consumables.
