3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Camera Chest Rest
Camera Chest Rest
When I fractured my right arm, I realised that handling a SLR camera with a plastered arm wouldn't be possible: the grip is on the right handside and so is the shutter release button.
After 6 weeks, when the plaster came off, my hand and arm were now to weak to handle the camera.
Luckily for me, this was a matter of time. Other people are less fortunate.
This has inspired me to develop an idea that I had during my period of discomfort and to share it with you in the "Health by Design Contest". If you like it, please vote for me!
The idea is simple: a device transfers the weight of the camera to your chest. This makes the handling of the camera very light and very stable (picture below was taken with one hand, shutter speed was 1/3 !).
All you need is some PVC tubing and a special hinge.
Note
This device can help people with a weak arm or hand, but it can be helpful to people with Parkinson to stabilise the camera.
Naturally it can be used for stabilising pocket cameras as well. You can then slim down the design by using smaller (copper) tubing. Moreover, you do not need a hinge as the lens is retracted in the camera.
Step 1What you need.
What you need.
* Two PVC pipes (length 70 mm, diameter 32 mm)
* One PVC pipe (length 170 mm, diameter 32 mm)
* A PVC T-piece that can accomodate the PVC pipes.
* A hinge. In the picture it's the rectangular Aluminium beam that will be cut to shape a hinge.
* A bolt and a nut (50 mm long, 5 mm thread).
20 comments
Jun 22, 2010. 1:32 AMjustjonty says:
What a great idea... will pass this on to my camera mad brother-in-law... thanks for the instructable!
Jun 18, 2010. 11:18 AMguyzo35 says:
Just built one for my dad, I think he's gonna love it!
Jun 20, 2010. 8:57 AMguyzo35 says:
Thanks for the tip! Here is my take on it: the limiting factor for me was the width of the aluminum hinge, (the biggest size I could find was 1"/25mm square), which decreased the diameter of the pipes, but otherwise I kept your given dimensions. Unfortunately, my dad has a shorter strap than yours, so I found a quick fix and showed him how to just tuck his straps under the chest rest, which serves the same purpose.
May 7, 2010. 12:21 PMmicobanff says:
 PVC tubing is so awesome and versatile! There are some other great DIY photo equip made with PVC tubing on http://www.diyphotography.net
Apr 25, 2010. 9:23 AMhogtowner says:
Another suggestion....use a remote for shutter release.  Those with Parkinson's could use both hands to steady them.  Or weak handed people, like you after the cast or people who had a mild stroke could easy look through the finder and leave their hand by their side to release the shutter.
Great idea.  A lighter and more portable version of the camera rigs used in films where the person seems to glide to a location as you are looking at them.  Of course, that faces the actor not the audience, per se.
Apr 25, 2010. 8:00 AMjamowa says:
Excellent design!  We have already begun assembling the materials.  Where did you find the caps for the pipe ends?
Apr 25, 2010. 9:54 AMRay-l-l says:
Wonderful idea I will have to try this.
Apr 15, 2010. 1:37 PMlemonie says:
I dislike PVC as a construction tool, but this is a really great build - I hope you get a win in the competition.
L
Apr 20, 2010. 5:07 PMnickodemus says:
Dislike PVC? Thinkenstein seems to disagree... Why don't you like it?
Apr 21, 2010. 11:17 AMlemonie says:
It's synthetic, needs glue usually wood / other natural materials appeal to me more.
L
Apr 20, 2010. 5:09 PMnickodemus says:
Great idea, this is great for those with Parkinson's disease. I'm sure it also keeps the camera fairly steady, I hope you win!
Apr 19, 2010. 9:02 PMlordofthedonuts says:
that's a great idea! I would definately use it in low light conditions.
Apr 15, 2010. 8:00 PMbullen says:
 I see this as a great useful aid, good luck and thanks for the camera rest
Apr 15, 2010. 10:54 AMEntropy512 says:
Hmm...  A variant of this might be great for supporting my Bigma, and far less scary than a BushHawk.
Apr 15, 2010. 10:05 AMgmjhowe says:
 This is a great idea, even for normal photographers the extra stability can make the difference. What I like most is how the camera is worn around the neck as per usual, yet you can just flip it up and support and use the camera.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
69
Author:bertus52x11
