Surprise Lollipop Nut!
Introduction: Surprise Lollipop Nut!
In this instructable I will show you how to make a lollypop nut surprise!
Step 1: Get the Materials.
You will need:
- wood glue
- a knife with a rather thick blade
- a surprise
- a peace of opaque plastic sheet
- a straw or lollypop stick
- a walnut
- a toothpick
- a small rubber band
Step 2: Lobotomy
Now you will have to get to the brain out of the nut. Do that by inserting the knife in the nut's back head as shown in the picture.
Step 3: Insert the New Brain.
Now lay the old brain in a bowl, put glue on the edge of one of the nut halves with the toothpick. Insert the new brain (the surprise) and put the too halves of the nut together. Now remove the excess glue on the sides with the toothpick you used earlier and now you wait for about 20 minutes.
Step 4: Stab It
Now that the glue is dry stab the nut with the lollipop stick or straw in the nut's back head. Usually it stays tight enough. If you hold the nut with the straw/lollipop stick downwards and it doesn't fall out it's fine. If it falls out use a little bit of glue.
Step 5: Choke It With the Bag
Get the plastic sheet and wrap it around your lollipop surprise nut and fix it with the rubber band.
Now give it to a friend.
Hope you enjoyed it!
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Science of Cooking
      Science of Cooking
    how do you get your pictures so clear?
    I used a panasonic DMC-TZ5 with inteligent auto on
    inteligent auto makes the camera zoom itself.
