You may have seen my first survival bracelet instructable on the cobra braid.  After receiving a comment from lightchaser mentioning the chain sinnet braid, I thought that was a great idea.  This is truly a Survival Bracelet, if you are in need of some rope or cord, you can just pull both ends and then you have one full piece of 8 ft cord.  Give it a try and see how simple it really is.
Step 1: Supplies
In order to make a survival bracelet you will need
-About 8 feet of 550 Parachute Cord (or whatever you have on hand)
-Pair of scissors
-Lighter
-Pliers (not necessary but can make a tighter bracelet)
Step 2: The Lanyard Knot
The lanyard knot is a nice way to spruce up your bracelet, but can easily be replaced with an over hand knot.  First make a small twist in the cord.  Then make a "U" shape beneath the loop.  Take the piece that points left and place it over  the bottom loop, and under the right piece.  Then over, under, and then over again.  Hold the bottom loop down.
Step 3: The Sinnet Braid
This braid is very simple once you get it down.  Make a small twist or loop in the cord.  Then make a "U" shape and put it through the other loop.  Pull tight.  When the loop is facing left, then place the left piece through the loop.  Continue until the bracelet is long enough.
Step 4: Finish it
First, put both pieces all the way through the last loop.  Then, as before you can make a lanyard knot again or an over hand knot.  Trim the end and then melt it down.   There you have it, a true survival bracelet.
1-40 of 64Next »
DragonSlaveArmory says: Feb 27, 2013. 12:25 AM
This is perfect for what I needed. I searched through 21 paracord pages before I found this one. Thanks. Super easy and fast to do.
DaDerp says: Feb 11, 2013. 12:32 PM
LOVE this weave. It's very simple, easy, and unravels quickly!
donnarodger1 says: Feb 1, 2013. 4:53 PM
do you NEED a lighter and can you make a braccelet without one. :)
mrknifeman says: Apr 4, 2012. 3:04 PM
the best and easiest and most practical one i found! i like taking my bracelet apart cuz i have so many other uses for it. easy to take apart and easy to tie. thanks!
schnerdly says: Aug 23, 2011. 1:40 PM
Pulling just unwinds the braid. These directions are very unclear
tevers94 (author) in reply to schnerdlyAug 23, 2011. 3:53 PM
When you pull each braid tight, keep a finger in the loop. This video might help.
http://www.youtube.com/watch?v=sGklOhpBMKA
thestyrofoampeanut says: Feb 7, 2010. 12:56 PM
 i was having a lot of trouble with this knot
if anyone needs help, this vid helped me a lot http://www.youtube.com/watch?v=faO3rY9G_Ns
tevers94 (author) in reply to thestyrofoampeanutFeb 7, 2010. 1:19 PM
That is actually the vid i learned from, so this is a good addition.
atuttle1 in reply to tevers94Aug 22, 2011. 6:00 PM
I don't even understand the video
tevers94 (author) in reply to atuttle1Aug 22, 2011. 7:21 PM
If you can't get the lanyard knot, then try using a simple over hand knot.
Happyn3ss says: Aug 8, 2011. 9:03 PM
Just wondering, how far should the knot start from either end of the cord?
tevers94 (author) in reply to Happyn3ssAug 8, 2011. 10:44 PM
I'm sorry, but I'm not sure what you mean. If you're doing two lanyard knots then just make sure when the first is done the loop is big enough to fit the other lanyard knot through. And be sure to keep both pieces after the knot at equal lengths. If that doesn't answer your question let me know.
Happyn3ss in reply to tevers94Aug 9, 2011. 10:00 AM
Never mind, I managed to figure it out on my own, nice article by the way.
tevers94 (author) in reply to Happyn3ssAug 9, 2011. 9:02 PM
That's good to here, and thanks. :)
stormskater216 says: May 31, 2011. 2:05 PM
can you post an article on this? im really confused....
clax1227 says: Mar 8, 2011. 2:54 PM
The actual name of this sinnet is the zipper sinnet
haws24 says: Dec 27, 2010. 10:08 PM
Thanks for the instructable! I have made four now and it's pretty slick.
By Keith says: Nov 2, 2010. 8:11 AM
Thanks for the instructable. My first project with paracord, sort of. Bought some cheap chinese stuff from Academy since the army-navy was closed. Made it for my wife who has just lost her dad (Air Force.) When I explained what it meant for vets it made her day. Kinda cool for me too as I lost my dad (Airborne) three years ago. Not a vet myself but grateful for all they have done.
unominame says: Feb 24, 2010. 7:23 AM
i think for multicolered bracelets you should dye it one side one color and one side another so you dont have to use two ropes
dhopper122 in reply to unominameOct 3, 2010. 3:37 PM
I tried the dye method when I was in Iraq my first rotation back in 2005. I used white 550 and permanate markers. Since the fibers themselves werent dyed, the permamaker dye leached out over time. What I found to work best for a two colored braclet is like I noticed in another comment on this site. Take and seal one cord, both ends. You will want to roll them to a point, will explain this later. Then seal only one of others end. The end not sealed, pull out some of inner cord; take out about 1/4 to 3/8 of an inch. Lightly melt the end. Use a needle to aid you in threading one of double sealed cord ends into the open ened cord. Once in, use a heated needle or larger to fuse the inner and outer cords together. I do another opposite the first and then turn 90 deg. and repeat. The rolled pinty ends will allow the maker to guide the one cord into the other with less hassles. Plus, when you use the needle to guide/ push the cord in, it gives a heard area to push against. And yes, I have had some pull apart while thightening. This is one of the best methods I have developed in my building techiques.
tevers94 (author) in reply to unominameFeb 24, 2010. 10:39 AM
GENIUS!!!
rogerrabbit321 says: Aug 11, 2010. 5:36 AM
that kind of stinks! Oh well! when you need it, you need it. Can't do much about that. thanks
rogerrabbit321 says: Aug 5, 2010. 8:03 AM
That's really cool! i especially like the red and white one. but when you need some cord for an emergency when you have to repair or make something, how to you get the cord? do you have to undo the knot and everything? Or is there another way?
tevers94 (author) in reply to rogerrabbit321Aug 8, 2010. 1:07 PM
You have to take it all the way apart. There's no way to save it .
StanUK says: Aug 1, 2010. 2:22 AM
I think I have worked out how to do it... Is it the same as this knot ?
StanUK says: Jul 31, 2010. 2:36 AM
Hi, Lovely tutorial.. Im trying to make one of these at the moment and I am having some difficulty. Is this the standard knot?
iwrite says: Jun 29, 2010. 5:30 AM
Hi, great tutorial! I love being able to make something out of a single piece of paracord -- no beads and extra cord etc necessary. I couldn't do the lanyard knot until I came across this tutorial and followed all the various links. I still had problems with it, but this diagram really helped me, so I'll link to it here just in case it helps somebody else: http://whatknot.tripod.com/knots/knot.htm
Millerspal says: May 5, 2010. 5:55 AM
I really like the quickness that this bracelet can be released in (compared to the cobra weave). Instead of knotting the bracelets, I bought a bunch of buckles and am going to try to work this bracelet using a buckle. I will let you know how it goes...Being in Afghanistan means I get alot of practice time.
I actually made a PDF out of screenshots from TIAT's river bar bracelet (for when the internet dies....the frozen pictures help tons...lol.
DreadFred says: Apr 30, 2010. 11:33 PM
I'm not  trying to be a "grammar nazi" but in the first sentence of the intro it says "The lanyard not".  instead of knot.
tevers94 (author) in reply to DreadFredMay 2, 2010. 4:21 AM
Not any more, thanks
Lindley says: Feb 14, 2010. 8:16 PM
Many years ago when I was on holiday in Sicily, I made one of these bracelets; locals were so  intrigued by them that I sat on the pavement and sold them! Some I made out of basic string, but a word of warning. I was wearing one myself  when I jumped into the sea for a swim, but the string contracted dreadfully and cut off all circulation to my hand. Only with difficult did I manage to cut the bracelet off in time.
JMan5 in reply to LindleyApr 22, 2010. 8:50 PM
How tight was it on your wrist? Because I had a river bar bracelet on my hand that got wet, and it shrank, but not enough to cut off my circulation. Glad your okay, though.
JStrider says: Apr 8, 2010. 11:31 AM
I did this with 2 cords doubled up.  makes the final product a bit more bulky, but I think it still works as an anklet.
took a bit of time to get the lanyard knots looking nice, had to get all the cords lined up and not crossing.  but the braiding portion worked well with 2 cords.
tevers94 (author) in reply to JStriderApr 8, 2010. 5:29 PM
It was funny to hear that because today i was thinking i wonder if that work work or look good, so its great to hear that it does.  im gaoing to try that tonight
JStrider in reply to tevers94Apr 12, 2010. 9:59 PM
let me know how it turns/turned out...
maybe try using a knot that is more streamlined then the lanyard knot,  it makes it hard to cross my legs because the knot is too big.
JStrider in reply to JStriderApr 12, 2010. 10:00 PM
also gotta use more cord... I think I used 12+ feet for each cord.... dont remember for sure tho.
zipzapper859 says: Mar 25, 2010. 3:07 PM
is this in the middle of the cord?
tevers94 (author) in reply to zipzapper859Mar 26, 2010. 1:54 PM
No, but i see the last picture looks looks that.  it is at the end of the bracelet, and the two pieces coming out the end are cut off.
zipzapper859 in reply to tevers94Mar 26, 2010. 7:08 PM
ok thanks that is why it didn't work
tevers94 (author) in reply to zipzapper859Mar 27, 2010. 2:52 PM
no problem, glad to help
1-40 of 64Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
