Lay the inner core of the bracelet on a flat surface or your lap. The take your long piece and fold itin half evenly, then place that behind the inner core. Then make an "S" with the piece to the right, top of "S" behind inner core and bottom in front. Put right end of cord down through bottom loop of "S" then under the center and up through the top loop of the "S". Pull tight. Then create a backwards "S" and repeat the steps from the first "S". Pull tight. Repeat these processes until there is no space left. At this point cut the excess cord and melt the ends down.
had a little trouble at the start, but eventually got it figured out
now i'm pleased with the result
I'm not daft...ive made tons of paracord utilities...but your directions are lacking depth or detail in these beginning steps. (for this style) You should show the ends of the cords in the initial layout photos. It's hard to tell from what you're showing where the long and short ends should be to start with. Also you say to fold the outer cord in half evenly, then place it behind the inner cord...then its magically an S? Just saying, it could use some more details. ;-)
Thanks for having something out here though. I have been making square paracord lanyard ends and zipper pulls for my MIL gear for ages, but came across these paracord how-to's on instructables, and thought I would try something different.
Cheers,
Scott
I made the bracelete following the above instructions but it doesnt look like the bracelete that is shown in the beginning of the instructions even though i used two colors. i just had the color down the inside center of the bracelete, not on the edges like its shown in the pic above. How is that done?
Thanks,
bill
