3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Survival Kit in a tin (better than other ones i've seen here)
Survival Kit in a tin (better than other ones i\
Marooned in the wilderness? Here's the answer to your problems:
a portable survival kit that provides all the essentials for preparing shelter, food gathering, fire making water cleaning and storage, signalling, and first aid. The entire kit has everything you need to keep you going for at least 3 days.
I am not held responsible for any deaths in the wilderness caused by misuse of this kit.
This may save your life!
Step 1You Will need.
You Will need.
You Will Need:
An Altoids tin, boiled sweet tin or tobacco tin: As well as holding everything, the inside of the lid is highly reflective and can be used to signal to rescuers.
A folded square of tin foil or aluminium foil. This can be fashioned into a small pan for collecting and boiling water, for cooking, washing and drinking out of.
A loud whistle of your favourite kind.
A short piece of sealed drinking straw, containing domestic bleach for water purification. This Provides about 8 drops of bleach. One should be enough to sterilise a PINT of drinking water.
a condom for water storage [or other purposes if you hit lucky ;) ] these buggers store A LOT, but be wary not to overfill it, as these are susceptible to bursting.
A dozen matches dipped in paraffin wax. Dipping them in wax keeps them completely dry - what's more, you can eat the wax scrapings, SERIOUSLY!
A candle stub. Has many uses, such as: a waterproof light, lubrication, and foodstuff.
Three 1-in squares of inner-tube rubber: AMAZING waterproof fire lighters.
Three Vaseline-covered cotton wool balls. Another multi-use tool: An affective waterproof tinder, First aid swab and lubricant.
A soft pencil, obviously this is a good message writer, but it's lead will provide an excellent lubricant, it's shavings can also be used as a dry tinder.
Three over-the-counter antihistamine and three "jungle-runs" tablets. These stop you being disabled by allergic reactions and dehydration.
A small roll of waterproof surgical tape. In addition to its obvious first-aid uses, you can make essential repairs with this or even put some on a branch to catch insects- a protein-rich food or bait.
A sugar lump (Cube). Use in combination with your tape to catch bees and insects for dinner. Bee soup is VERY nourishing.
Six safety pins. You Can use these for emergency clothing repairs, and as an aid to shelter construction. They make good fishing hooks too. Just attach a caterpillar, and a piece of foil as a lure and you're away.
A stock cube. This simple item will improve the taste of some of the ghastly stuff you have to eat.
A small Swiss army knife. For skinning, gutting, sawing and so forth. (it's tweezers are good for plucking eyebrows, if you are a loose end).\
10ft Multi-strand parachute cord, wrapped around the tin. In addition to its uses as shelter suspension, strung between trees, it can be used for hanging food out of the reach of animals, and it's inner filaments are PERFECT for sewing, snare-manufacture, tying off your water container, and especially fishing. They also make ideal dental floss.
20 comments
Aug 28, 2011. 11:59 AM08motooley says:
this is copied from Tom Cutler's "211 things a bright boy can do" though
Aug 4, 2011. 12:08 AMmooner77 says:
This is a great ible but one very important thing u missed was wire or twine And some floss or thin rope. The wire comes in very useful when you are trying To Make a pot with foil. Just two circles above each other wire To connect them And cover in foil now you have a pot And or cup. : )
Apr 28, 2011. 11:14 PMgcollin says:
Why the hell would you use a condom for water storage, it is just stupid!.
May 9, 2011. 7:45 AMAce_Of_All_Trades says:
Look around on some survival sites. Most survivalist do actually recommend carrying un-lubricated condoms for water storage. Before you comment at least google the topic to see if you know what you are talking about.
May 12, 2011. 2:14 PMgcollin says:
There is no way I am carrying a condom with me for water storage, I would rater just carry a water bottle.
May 30, 2011. 5:07 AMjamesjamesjames says:
this is a survival kit to fit in a small tin.. good luck getting a bottle in their! when i have done it, i put the condom inside a large sock or hat to give it some rigidity and prevent it from bursting when collecting water.
Jan 28, 2010. 2:22 PMBroom says:
"you can eat the wax scrapings, SERIOUSLY!" - true, but they provide absolutely no nourishment. You can eat grass, toenail clippings, and tiny pebbles, as well.
"This Provides about 8 drops of bleach. One should be enough to sterilise a PINT of drinking water." - that's massive overkill (no pun intended). 1 drop per pint is the standard recommendation. At room temperature, the water should sit for 30 minutes before drinking. Below 60 degrees, it should sit several hours. The resulting water should have a very slight chlorine taste. At the recommended "8 drops/pint", it might even irritate your mouth or throat.
The aluminum foil should preferably be "restaurant grade", which is stronger.
Other than these points, this is a decent guide.
Jan 1, 2011. 11:52 AMtincanz says:
Actually, if the wax is based on animal fats, it will provide 9 kcal per gram...
...but the amount used to cover a match head is not very large.
Aug 4, 2010. 1:29 PMMomghoti says:
The Cedar fire in San Diego killed 15 people and destroyed over 2000 homes, and was started by a hunter to signal rescuers. Definitely be smart when it comes to fires!! If the area is very dry (like, maybe, Southern California) be extremely cautious--maybe avoid a fire all together.
May 9, 2010. 6:54 PMKittyF says:
thanks for the info on using a watch as a compass.   I'm sure that info is available on the web but it's nice to have it with all the other stuff.
Mar 1, 2010. 1:02 PMAaronsEve says:
I have noticed that no one has mentioned chalk for blazing trails. Specially considering if your not fimilar with the area and leave your base camp to get water or make/check your traps, ect.
Nov 14, 2009. 11:34 PMweaponscollector94 says:
unlubricated condoms are better cause one guy i know Frenchfry drank mild from one and got really sick. i am not sure why but i think it was not the lube! i recently made a pretty good mint tin survival kit, and i totally carry it with me everyday
Jul 16, 2009. 10:30 PMpyroliquidsnake says:
if you hit lucky lol good one man this helped me and my cuz out in da woods lol we got lost n came baack home a 3days later lol we survived on fish and cooking it on a stone grill and the condom was a great makeshift fishing net ;P
Jul 18, 2009. 1:58 AMpyroliquidsnake says:
we used wire from the inside of bacpacks to keep condom opening wide open and we maade a coupple of small holes on the other side to let water run thru lol the firs were baramundi so basicly the fish were about the avrage mans handspand ;) im guna make my first instructable on how to make a survival stone grill soon :P it worked pretty well
Jul 10, 2009. 7:35 AMHunter O. says:
Very good, but how do you fit all that in there at once?
Jul 7, 2009. 9:29 AMvinny129 says:
this is a rele good 1st. good job
Jul 6, 2009. 8:10 PMskater7832 says:
nice but you should have 2 ways of making fire like firesteel. Here are some really cheap firesteel rods, a mini or ranger size would easily fitin an altoids tin.
http://firesteel.com/fire/categories/FireSteel-Blank-Rods/
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:Scott Fry
