Intro: Survival Rings-yet another paracord project
I have been wanting to do this for some time. I finally have a ring that matches my paracord survival bracelet. Its fun and easy. It also uses the lef...
I chose colors that I had to match the survival paracord bracelets that i had already made. I measured about 9" out for one ring. This may vary accord...
Twist the paracord using your favorite weave. Then test it on your finger. Adjust to fit. It should slide on and off easily. But not cut off circulati...
I used my soldering gun with a spade bit to fuse the ends together. Just keep the ends together, then place the hot blade between the ends. When they ...
I decided to try the paracord rings with the seven inside strands removed. Called gutting. Not my favorite, but they are thinner, what do you think ? ...
Bio:Running the ranch, taxi, auto tune ups & maintenance, computer & printer fixing, chuck wagon (grilling & cooking good food), security, body-guard, protecting our natural environment, you know, I do ...read more »
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
