Introduction: Survival Supply Keychain
This is a simple key chain with a few supplies wrapped up in a small para chord key chain. The supplies could be used in a pinch when camping or hiking, although you hope you never need to! It contains a few feet of rope, a small knife, fishing line, fishing hook, and a strike anywhere match.
Step 1: Supplies
For this project you will need:
small pocket knife (I used a small swiss army knife that contains a small knife, scissors, file, tweezers and toothpick)
Fishing Line (I used about 10 feet)
Fishing Hook
Strike anywhere match
Sandwich Bag (not shown in photo)
Rope of your choice (Depending on the size of the knife you use length will vary. I used about 15ft, but had a lot of excess. about 6 ft would have been fine.)
Key Ring (not shown)
2nd knife or scissors (for trimming excess rope)
Lighter (to burn rope ends)
Step 2: Step 1
Begin by cutting the corner out of the ziplock bag so that the match fits inside and can be wrapped up. This will help keep the match dry. Tie the fishing line to the fishing hook.
Step 3: Step 2
Place the match wrapped in the plastic and the hook on the knife, and tightly wrap them both to the knife with the fishing line tied to the hook. The hook will act as an anchor. once wrapped tuck the end away so that the line does not come undone. I tucked the end of my line between the match and knife.
Step 4: Step 3
Cut your rope to the desired length, I cut mine to about 15ft, and use the lighter to burn the ends so that they do not unravel.
Find the center of your rope by folding it in half. take the center and insert it through the small keyring on the knife. Then feed the loose ends through the loop of rope just created. Pull the loose ends until the knot is tight.
Step 5: Step 4
If you have ever tied a para chord bracelet, than this step shouldn't be to hard. The same knot is used except the knife is now used as the center instead of rope.
Choose a front and back of your key chain, then choose an end of rope to be the front piece and an end to be the back piece. The first few knots are a little awkward to get started.
Hold the back rope to the back so that a loop forms. Feed the front rope through the loop. pull the front rope through, but leave slack so that a loop is formed by the front rope on the opposite side. Feed the end of the back rope through this loop created by the front rope. Pull tight so that the knot stays on the knife.
Repeat this knot down the knife. be sure to keep the knots tight, and be careful not to undo the fishing line as the knots cross over.
Step 6: Step 5
When you reach the bottom, loop back to for knots back up the knife on top of your previous knots.
This step could be repeated multiple times to get more rope on the key chain. I chose to stop after going back up.
Be sure to keep all your knots tight!
Step 7: Step 6
Once you have finished knotting your rope, cut the excess off, and burn the ends. the burnt ends will hold if your knots are tight.
Step 8:
Put the keyring on, and put it on your hiking/ camping pack!
Please vote for this in the out doors contest and the weekend project contest, and let me know what you think! Thanks!
Runner Up in the
Weekend Projects Contest
Great Outdoors Contest
