Then I thought that some fishing line in it would make the bracelet even more useful in a survival situation. So I knotted a bit and made an instructable out of it to help people makeing a survival bracelet themself.
Remove these ads by
Signing UpStep 1Things you'll need
- about 25 feet of paracord (depending on how thick your wrist is)
- a lighter
- scissors
- about 15 feet of fishing line (depending on how you knot it or how often you wrap it around)
Its useful for hooks, joiners, a spark in some situations or stuff like that.
As for using spider wire, braid will deteriate a lot more over time as compared to sun protected mono. But you could add braid as well, have a whole fishing setup with mono leader and braid main line hahaha
None the less, this is an excellent idea! Thanks for the instructable
note on the sling though, it probably takes 2 hours just to learn to make a good strong throw towards the right direction, and several months to learn to hunt effectively. not a good weapon for on the go survival, i recommend a bow which is at least directional.
Another option for the fishing line might be to put the line, along with a couple of small fish hooks, and possibly a few small lead fishing weights in a sandwich baggie, rolled up into a long thin length with the contents spread out, then placed over the bracelet's core strands to be knotted over.
You should figure out how wide the knots will be over the fishing kit, and make all the knots the same size from one end to the other for consistancy. You still have all your paracord and it may keep the the fishing line from being damaged/nicked as it might be on the outside of the bracelet, minus all the kinks in the line as well...
I already thought of fishing hooks but couldn't think of something to attach them. I didn't have much time as well because of the contest, but your idea is really great, thanks.
I still think that it's better to have too much than too less, the fishing line is not heavy, needs nearly no space and is easy to attach.
I just think that it's not a big deal attaching it and that it may be useful someday..
