Survival Fishing Without a Pole
4,606
77
5
Published
Introduction: Survival Fishing Without a Pole
About: I enjoy the outdoors but I wouldn't call myself an outdoor expert. I do risk management for a living so I tend to think worst case scenario in most cases. It makes me a lot of fun at parties .
Have you ever seen the PVC or stick survival fishing kits? The problem I have with those is that casting and reeling is painfully slow.
And the ability to put the bait where you need it is pretty important if you want to be successful.
This was a collapsible and pretty compact rod/reel combo. I put a better reel on the rod. In most cases better = heavier. And that's no good.
I keep the components in my go bag/ hiking gear. If you haven't seen it you can check it out.
You need:
A reel
A stick (green)
A knife
2 zip ties
Eye hooks (this package was about a dollar at Lowes)
Some tackle
Step 1: Find a Nice Stick
This was a sapling in my yard. Ideally you would find one that is really straight. This one had a little bend in it. I just trimmed the straight piece.
You can go a little longer. But I don't recommend making it too long. The thinner end will split when the eye hook is screwed in.
Step 2: Mark the Stick
Make the marks conservative. You want it to be snug when it's attached.
Step 3: Notch It
Make a nice flat spot for the reel. Also make a couple of notches on the back side the width of the zip ties.
This keeps the zip ties from slipping.
Step 4: Add the Reel
Add the zip ties loosely. This makes it easier to get it tight.
Snug the zip ties down and trim them off.
Step 5: Add the Eyes
If there is a gap just give it a squeeze with the Leatherman (you have it with you right?). This will keep the line from slipping out.
Add a few eye hooks along the new "rod". This is the reason you don't want to have the end too skinny. It will split it apart.
Step 6: Fish!
This will cast pretty darn well.
But considering this is a stick and not a little composite rod, you won't have the feel and control. So you really won't be able to win any tournaments.
Sorry about that.
This can be mitigated by keeping your finger on the line and feeling for the strike. You should be able to catch a little dinner (assuming the fish are biting).
Step 7: Things to Consider
Tie the line off so it doesn't get messed up in the bag.
You can choose a better reel if you want, but I am considering this to be something I am unlikely to need. And I would rather have my good equipment for the times that I know I will be fishing.
This reel is also very light. That's more important to me (in this circumstance) than durability.
That being said, this is a good reel that casts well.
My comments about the quality are more in general. I don't recommend using anything that doesn't work well in a survival situation. I also want to be sure this is an extra so that I am not tempted to take it out and use it, so it's in my bag when I need it.
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    5 Comments
    Great idea, Although you might consider a
    couple of alternates, a cheap spinning reel and/or welding, glueing, or
    soldering the joint in the screw eyes. Then polish them up to get rid
    of any areas that can nick the line.
    I like a spinning reel. In fact I replaced this one with one on my rod. But I don't know if I would say it is as easy to throw in the bag. But there are plenty of ways to get around that. I suppose it was more of a matter of "use what you got".
    The idea about the gaps is good. You could easily do that before you put them in the pack.
    Thanks for the comments
    Thank you
    nice instructable, good use for some older reels I have where the rod broke and I never bought a new rod, might even do this with a nice old Mitchell reel I have lyin around
