Suspension Stools From Scrap Steel
7,556
178
9
Posted in WorkshopMetalworking
Introduction: Suspension Stools From Scrap Steel
About: Art made from scraps. Instagram: Ollysartsnscraps
I found some cool pieces in a scrap metal bin, two domed circular pieces of steel and two curved circular pices of steel. I grabbed them out of the scrap bin with stools in mind. 6 months later after gathering more scrap, here they are!
Metal Contest
Third Prize in the
Metal Contest
Step 1: Tools You Will Need
-welder
-wire wheel
-cut off wheel,
-flapper disc
-grinder
-square
-measuring tape
- wire brush
-hammer
- level
Step 2: Materials You Will Need
- domed circular steel( or some sort of base)
- curved circular steel( or some sort of seat)
- spring( salvaged from old grain auger)
- 1"1/4 , 1/8" gauge tubing 21" long ( salvaged from an Old lathe)
-1"3/4 1/8" gauge tubing 12" long
-2"3/8 tubing 1/4" gauge 1-2"
Step 3: Clean Up Edges
Using a grinder and grind wheel, clean up all the edges around your seat and base
Step 4: Bevel Edges
Using a grinder and grinding wheel bevel the edges of the tubing
Step 5: Bring It Down to Bare Metal
Using a grinder with a wire wheel bring the tubing down to bare steel
Step 6: Welding Spring Stopper
Using a square, weld the 2 3/8" pipe to the 1 3/4" pipe. Tack weld all the way around. This will be flipped over and welded to the base.
Step 7: Welding Seat Post Onto Base
Taking the last piece you just welded, flipping it over, and centre it onto the base, using a 90 degree magnet and a level to keep it straight, tack weld all the way around
Step 8: Shining Up the Base
Using a grinder and grinding wheel, grind the base to bare steel. Starting from the middle and grinding around the post will give you a cool effect . Using a flapper disc afterwards to really make it shine
Step 9: Welding the Post to the Seat
Taking the 1 1/4" tubing again using the magnet and level to keep it straight, tack weld all the way around the post
Step 10: Paint the Bottom of the Seat
Taping off the post with tape and paper you can paint the bottom of the seat black( or whoever colour you want) . After drying completely go over with clear coat
Step 11: Putting It Together
Taking the spring( which can be cut at whatever length desired for comfort) slide it over the tubing attached to the seat.
Then slide tube into the tube connected to the base, and flip upright.
Step 12: Finishes
On the shiny stool I used a flapper disc and used it to make a design, the rusty one I used aluminum brightener acid which rusts steel. Both where clear coated.
And that's how I made my stools from nothing but scrap.
Thanks for looking
    • Microcontroller Contest
    • Science of Cooking
      Science of Cooking
    • Spotless Contest
      Spotless Contest
    9 Comments
    Thank you everyone. Yeah I found the auger on a farm! And the curved steel is just a piece cut out of a pipe.
    how do you get the curved seats?
    Where does one find an old grain auger? Presumably on a farm I would guess.
    nice work i like the brown one
    lovely. Good work. Always want to do welding myself but never learn to weld. Always an issue to ask someone else.
    Those are gorgeous! I particularly like the silver one, but they're both beautiful.
    Wow, they do look beautiful, would never imagine this is non factory made!
    These are fantastic. Beautiful, clean work!
