Sven From Frozen, Stable
215
Posted
Introduction: Sven From Frozen, Stable
I will try to thoroughly explain the steps that I took to make the stable. The supplies that I used for ,my Sven stable are listed below...
Thick Poster Board that I got at the dollar store [X2]
Popsicles sticks [X1 pack]would recommend X2 packs because I ran out.
Hot Glue Gun
Hot Glue Sticks
Duct Tape
Brown Acrylic Paint
I am sorry for the fact that I have not been able to show steps in any of my recent instructables. I will try to thoroughly explain the steps that I took to make the stable. But if you would like the exact measurements that I used please comment in the comment bar. Note: That Most Sven stuffed animals are different sizes, the one that my little sister got is from the Disney store.
Step 1: First the Base of the Stable
I measured the length of Sven then the width and cut a rectangle that fits the length of sven so it is not to small or big. Then for the walls I used the same length of the base but then measured the height of sven. Make sure to cut X2 of the walls and base. For the roof I used the second rectangle that should be the size of the base and cut it in half. Then get out your hot glue gun and glue your walls to the base piece then get your ceiling piece's and glue them together then onto the walls to create an angle.
Step 2: The Doors and Hinges
For the doors measure the width of the base and height of the walls to create a rectangle, then cut the rectangle perfectly in half, to create two squares. Then for the hinges I used Duct Tape I ripped a small piece off and folded it up. Then I hot glued one of the ends to the door then glued the other end to the outside of the wall. Repeat the process for the other door. I cut out small triangles on the side of the door, so I could open the door like a handle.I could only put popsicle sticks around the top door because like I said on my previous step I ran out of them.
Step 3: The Windows
All I did was first make the square out of the popsicle sticks the put a popsicle stick in the middle. then I cut out a square that fits the window, next I put the window on the house.
Step 4: The Fence
For the fence I just glued the sticks together into a circle kind of shape then glued it to the outside of the wall on the back of the stable. Next I put popsicle sticks under parts of the fence to hold it up. That is all I did for this instructable. Thanks for viewing!!! If you would like the exact measurements that I used please comment in the comment bar. Note: That Most Sven stuffed animals are different sizes, the one that my little sister got is from the Disney store. Thanks, I love feedback on what would make my instructable better. :)
    • Spotless Contest
      Spotless Contest
    • Space Challenge
      Space Challenge
    • Science of Cooking
      Science of Cooking
    2 Comments
    Thank you @ClenseYourPallet
